10-24-2005, 06:04 PM
Heres the issue, the car runs very rough if at all at idle and you cannot give it any gas. As soon as you do, it bogs down and dies.
Codes pulled p0300(i think) Random Multiple Misfires, basically getting misfires by the hundreds on all cylinders.
Replaced the fuel filter, swapped the entire IDI cover and coils....same thing....cannot figure it out for the life of me... The injectors have proper voltage, TPS seems to be working via the scanner. Fuel pump relay fine.
Diagnostics for that code states either sensor or ignition problem. Where in there it is i have no idea....The only thing I have not done was get the fuel pressure reading to make sure the fuel pump is working properly, but have no way to check it.
Gimme ideas please, I just spent over 2k in this motor and now it does this shyt. I just said screw it and went out and bought a brand new motorcycle, but now its getting too cold to ride it every day....need to fix the hoe!!!
AnderbrA Innovations
Custom Automotive Lighting
www.anderbrainnovations.com
07 Cadillac STS V8
07 Mitsubishi Galant ES
00 Olds Alero - Parts
02 Lincoln LS V8 Sport - RIP
10-24-2005, 06:17 PM
Sounds like your ignition module is toast to me. Same thing happened on meh ecotec.
If I did went to college...
10-26-2005, 10:23 PM
swapped out the entire IDI cover....coils and ignition module....did the same thing. We tried some starting fluid and wd40 in the intake and it did manage to idle a lot smoother for a bit, so we are thinking the fuel pump may be getting weak.
07 Cadillac STS V8
10-26-2005, 11:47 PM
Do the 2.4s come with a maf sensor? On my 1.3 DOHC Suzuki engine if the maf isn't connected it will idle but will die as soon as you give it gas.
10-27-2005, 11:19 AM
there is a sensor, i believe its the plug on your throttle body all the way to the right, the 3rd one
10-28-2005, 01:20 PM
there is no MAF sensor on the 2.4 the main sensors on the TB is the Idle Air Control, MAP, TPS and some vacuum connections...
some progress.....its not the fuel pump, i finally checked the pressure at the fuel filter and I am getting 40psi when the pump engages.
so basically back to the drawing board.....
07 Cadillac STS V8
10-28-2005, 11:45 PM
Owner
are you flooding the hell out of it?
is your TPS reading correctly?
are you using a 2.3 or 2.4 TB.
get a wide band so you can read if she is running rich or lean.
check spark plug gap. possible change spark plugs. what brand and heat number you running. is it stock heat rating?
what about the knock sensor?
i think you should have a full diagonistic ran on it to give yourself more if.
Beware of the BackStabber
10-31-2005, 11:19 AM
nope not flooded, not doing anything with gas,
TPS reads correct % of throttle whether car is running or not.
stock TB and IM
ODBII scanner showed 0% lean or rich
new spark plugs, had bosch +4s, now have NGK
Knock sensor should throw code, and retard timing.
any other ideas....
07 Cadillac STS V8
11-02-2005, 02:27 AM
Try Checking the ground! When i put my motor back in for some reason it didn't run right, so i just upgraded a direct ground from the battery to the block. Thats probably not gonna solve your problem.
ANother issue that helped the first time i rebuilt my motor was that the o2 sensor (precat) went bad, got a new one and she ran like a champ! i would around there as well.
Good luck and keep us updated!
11-04-2005, 02:26 AM
PCM problem? maybe
11-04-2005, 11:10 AM
Plugs wires crossed?? lol
Could be a bad cam or crank sensor, those are used to trigger the ignition, never heard of one failing but....?? Also the knock sensor will only throw a code if it senses knock, not if the sensor is bad or malfunctioning, gotta love OBDII :rolleyes:
FWIW those sensors cost $19-$33, a piece, from autozone online.
I'm on a boat.....
11-04-2005, 12:01 PM
2.4 dont have plug wires.
11-05-2005, 01:15 AM
Originally posted by AftermathAlero+Nov 4 2005, 11:01 AM--><div class='quotetop'>QUOTE(AftermathAlero @ Nov 4 2005, 11:01 AM)</div><div class='quotemain'><!--QuoteBegin-Fast Eddie@Nov 4 2005, 04:10 PM
[/b][/quote]
DUH, hence the "lol"
I'm on a boat.....
11-05-2005, 01:20 AM
Originally posted by Fast Eddie+Nov 5 2005, 06:15 AM--><div class='quotetop'>QUOTE(Fast Eddie @ Nov 5 2005, 06:15 AM)</div><div class='quotemain'>
[/b][/quote]
DOH! .. that was when i just woke up in the morning at 11am. Went straight to computer for the usual forum browsing.
11-07-2005, 05:56 PM
I am going to try the crank sensor tonight....it would have more relevance than the cam sensor.
07 Cadillac STS V8
11-08-2005, 12:15 AM
ignitions system definately fails, cause mine did! Check it all!
11-10-2005, 11:11 PM
plugs aren't soaked? no delivery? Does it idle fine all the time till you give it gas?
I'd say it's the FPR if anything, the pump may be a good idea too tho, but I dunno.
Have you ever gone through constant starts and pulled the plugs to see if they're stinkin like gas?
old spark test, use a screwdriver and see if they're producing
seems odd anderbra
smirking is important
follow the titans
11-13-2005, 12:00 PM
Wowo It's been ages since I posted.
P0300 Random Misfire detected.
First, clear the code. Test drive using OBD II scanner set to record data, Set recording info as follows O2S2, MAF(hg), CAL Load, IAC, TPS(%), Vehicle Speed, MAP, Fuel Trim. Set condition for code trigger.
When the code trigger the recording You will have the nesacrray info to view not the junk thats irrevlant.
After clearing code, P0300, and either P0301, P0302, P0303, or P0304 should appear, By narrowing down to two codes, you can determine which cylinder is actually misfiring. Since we don't have wires to check for spark, The only way to narrow this down is to do a functional test using OBD II. Since Im assuming this is a project car Bryce you might not have the need tools.
In this order, remove one spark plug boot from the cylinder replace cover and hook up test motor, if the motor is still the same that means you found the faulty cylinder, if the motor is running rougher than before you removed the boot, then that cylinder is good.
Once the faylty cylinder is found. you need to determine if spark is the issue fuel, or compression.
First check to see if spark is working by removing cover and placing a old spark plug in the boot put the tip on a good ground in the engine bay. (Note make sure not near the fuel rail, and make sure no carb cleaner near the plugs, Have friend crank the vehicle. if all four plug are sparking then ignition system coil is ok. If none or more not sparking, then could be PCM, Ignition system, Camshaft postion Sensor, grounding or muplty things.
Move on to Fuel, check using an led atteched to a good length of wire. Connect injector wiring harness(DON NOT REMOVE INJECTOR FROM MOTOR) to the led. Have friend crank motor if the led lit up then injector is reciving power. If not, possibly grounded wiring, PCM, CPS (Crankshaft Postion Sensor),
Check for compression using a compression gauge. HAve frined crank motor. Check the pressure. Since Im home today, I don't have the PSI it should be but check to see, if the intake is leaking air, head is leaking or what.
Hopefully this helps you get started. The best way is to figure what is the cause. A code only gives you a system. Tried to narrow it down to a system or component,.
11-14-2005, 06:38 PM
brand new rebuild, forged internals.
new plugs
p0300 is even after codes are cleared.....equal number of misfires for all cylinders.
replaced crank sensor...no change
swapped ignition system...entire top end...no change
fuel pressure approx 40psi at fuel filter
new fuel filter
idles hardly.....and hardly idles....very rough half the time it dies.
no other codes, sometimes the trac off light will randomly come on while its trying to idle...
we used the odb ii diag scanner, not just a code puller, i guess i dont know what the specs are supposed to be for each sensor etc. but nothing looked out of the ordinary.
TPS functioning properly
not lean or rich
07 Cadillac STS V8
11-14-2005, 10:49 PM
:rolleyes:
