Old 08-01-2005, 09:59 PM   #1
cruisinalero
cruisinalero is an unknown quantity at this point
there are the 2 194 bulbs for the dome light that are in the "condoms"...
i was wondering how i can remove these...
cruisinalero is offline   Reply With Quote
Old 08-01-2005, 11:23 PM   #2
cruisinalero
are the bulbs soldered into the "condoms"...
i cant pull them out...
Old 08-01-2005, 11:38 PM   #3
smlzalero
where my knickers at?
smlzalero's Avatar
smlzalero is an unknown quantity at this point
If you mean the gray plastic thyng that plugs into the board.. no, they're not soldered. The wires that are part of the bulb get melted onto the contacts in the "condom." You just have to either yank the bulb out or you can take a pin like I did and break the wires off the contacts.
--UPDATE-- $88,000 in debt.
smlzalero is offline   Reply With Quote
Old 08-01-2005, 11:48 PM   #4
cruisinalero
no the bulbs in the blue "condoms" in this picture
Old 08-01-2005, 11:55 PM   #5
Whitetigerboi83
Whitetigerboi83's Avatar
Whitetigerboi83 is an unknown quantity at this point
Send a message via AIM to Whitetigerboi83 Send a message via MSN to Whitetigerboi83 Send a message via Yahoo to Whitetigerboi83
why take them out get replacements http://www.superbrightleds.com
Whitetigerboi83 is offline   Reply With Quote
Old 08-02-2005, 12:29 AM   #6
cruisinalero
i need the condom to complete the connection
unless i want them just dangling there
thats what im trying to do is replace them but i cant get the regular bulb out of the condom so i can put the leds in there
Old 08-02-2005, 12:29 AM   #7
smlzalero
smlzalero's Avatar
It's the same thing.. but yeah, lol, it would be just as easy to just replace them.
Well, they look like they function the same way. the wires look like they should be able to be seen on the back of the "condom".. just pick them loose and yank the bulb out.
Old 08-02-2005, 12:31 AM   #8
cruisinalero
well ive tried to pull them out...
it seemed like i was going to crush the bulb...
how do you break the connection with a pin
Old 08-02-2005, 12:33 AM   #9
cruisinalero
i dont no it seems to but stuck in there...
ive replaced the 194's in the front under the dash...
they just pulled out....
Old 08-02-2005, 12:38 AM   #10
smlzalero
smlzalero's Avatar
you have the bulbs & condoms out right? look at the back of the condom.. you can see the metal pieces that the wires from the bulbs make contact with? just take a pin and run it between the wire & the metal piece on the condom.
Old 08-02-2005, 12:38 AM   #11
Whitetigerboi83
they twist and pull out but if you get the replacements from http://www.superbrightleds.com they have the new "condom" already on them no need to try to pull out the old ones to put in the led ones .. they also have ur festoon bulb there the one in back of the dome but just twist the blue part on the bulb it will slide out of the dome.. its the same type they use in the instrument cluster lights .. just twist them they should come right out
Old 08-02-2005, 12:40 AM   #12
smlzalero
smlzalero's Avatar
yeah, i could be wrong, I ve never messed with those particular bulbs but they look the same
Old 08-02-2005, 12:41 AM   #13
cruisinalero
didnt see any 194 bulbs with the "condom" on that site...
i did see the bulbs that would fit into the condoms though...
Old 08-02-2005, 12:43 AM   #14
Whitetigerboi83
http://www.superbrightleds.com/1157.htm
almost all the way down they have the festoon bulb and instrument cluster and gauges bulbs thats the same ones you need to use in the dome lights they may not be blue but their the same ones
Old 08-02-2005, 12:46 AM   #15
cruisinalero
i dont think the bulb #74 will work for to replace the 194 with the condom...
Old 08-02-2005, 12:48 AM   #16
cruisinalero
this bulb???
Old 08-02-2005, 12:52 AM   #17
Whitetigerboi83
trust me its the same thing they have been using these bulbs in cars and trucks for almost 20 years my 85 vw cabriolet has the same ones my 91 gmc truck and my 2002 alreo has in them and i've seen 79 and 80 gmc trucks with them at the salvage yards they are all interchangeable if you need to go check with the dealer but 2 bulbs from then would cost you almost 10 bucks and not be leds... the twist and lock part are all the same size they are just changing the number/intensity of the bulb
Old 08-02-2005, 12:55 AM   #18
cruisinalero
the thing is that i already have the bulb that goes into that condom...
Old 08-02-2005, 12:55 AM   #19
Whitetigerboi83
Originally posted by cruisinalero@Aug 1 2005, 10:48 PM
this bulb???
yes thats the same kind the number is only telling you the type of bulb the twist and lock is the same size ad the blue ones in ur dome
Old 08-02-2005, 12:58 AM   #20
Whitetigerboi83
well to get the old one out and put the new one in try taking it out like you would change a x-mas light bulb form its holder bent the two tabs down str8 and put it out :-P put the new one in and bend them back
