Old 03-17-2005, 06:28 PM   #1
jackal
Ok I need to install the air intake i got for christmas. LOL I need to know a few dummy questions? should I take the MAF off and if I need to will it screw it up, also in the stock filter the bottom will I need to rip that out or should I?
Old 03-17-2005, 06:59 PM   #2
King Asoka
King Asoka's Avatar
i assume there are no instructions included with it.
by the looks of the picture on dr.speed, all you have to do is remove the top half of the air box and everthing after the MAF away from the engine. hmmmm, i hope u can follow that. anyway, then install the new piping and the filter and your done.
good luck.
If you can post a pic of your engine before, then we can use paint to illustrate what you have to do.
Old 03-17-2005, 07:34 PM   #3
jackal
thanks that what I thought I had to do but I wasn't totally sure. Thanks and one more question. I do put the couplet in the stock black tubing.
Old 03-17-2005, 07:59 PM   #4
FormulaNERD
remove everything connected to the throttle body, airbox, top and bottom, tubing... EVERYTHING.
then install wai.
