02-10-2005, 10:34 AM
AutoCross Alero
ok i got this from Jason at DHP, due to the extent of modifications i'm doing within the next month he suggested this.
DHP Powertuner
02-10-2005, 12:57 PM
so.....that means what? thats better than the older one?
AUTOBOT
02-10-2005, 01:38 PM
You spoke to Jason?
Good luck getting a call back.
02-10-2005, 01:47 PM
AutoCross Alero
i don't normally have a problem getting hold of him, he gets back with me fairly quickly.
and ALERO its a programmer so you can adjust settings, i'm installing stage 1 heads, stage 1 supercharger cam, u/l manifolds, headers, 62mm/TB, pro-m maf, and 8psi boost, bulletproof tranny and some more suspension mods. they have suggested the programmer to me because of the adjustments needed for fine tuning.
02-10-2005, 01:48 PM
yes, you can update your flash program for mods and stuff like that yourself with a tuner module, instead of mailing your pcm in. and i think they let you do another compatible gm car too (for a friend)
02-10-2005, 05:31 PM
so do you just order this and, you get to program your pcm yourself?
AUTOBOT
02-10-2005, 06:31 PM
yup
2001 Alero GLS - Sold!
02-10-2005, 09:55 PM
mmm guess i'll have to pick me one up soon then.
AUTOBOT
02-12-2005, 11:20 PM
Senior Member
warning. this is not a novice piece
you can seriously screw things up if you dont know what your doing.
if its not somthing your sure you know how to do you may want to consider a custom tune from dhp instead.
or just majorly do your homework before tearing into this
now sporting 3 pedals
<img src=\'http://invision.aleromod.com/uploads/post-25-1071111759.gif\' border=\'0\' alt=\'user posted image\' />
02-13-2005, 09:30 AM
there is a seperate DHP Powertuner only forum that tells you how to modify your own PCM and quite a few people there to help and answer questions. if/when you buy the powertuner, DHP will tell you how to gain access to that forum.
and the actual changing of the PCM tables isnt that hard or knowing what to change is not hard, but actually figuring out how far you can go before you blow something up is the scary part.
ive been using the powertuner for almost 9 months now.
02-13-2005, 11:26 AM
delete
02-13-2005, 01:33 PM
Senior Member
bingo.
this might be a nice accessory for those that dont want to play on the dyno every time they tune. its tsomthing I'll be picking up for use with my tec 3
wide band commander
02-13-2005, 01:50 PM
cool thing about the Powertuner is that you can opt for a wideband I/O on the interface and it works with the powertuner scantool. so the only thing you would have to buy is the 5volt WB O2 sensor.
and iirc, honda makes one for some of there cars and is stock and runs like $75 for the sensor.
02-13-2005, 02:15 PM
AutoCross Alero
Hey Springs, when I get to tuning you may be hearing from me.
