03-03-2011, 01:54 AM
Present in the mail... :)
Under construction...
03-03-2011, 04:12 AM
Aq sundown?
03-03-2011, 05:21 PM
Keep guessing...
03-03-2011, 05:22 PM
Items Features Voltage 5.0kw
Output Power (RMS) at 4 ohm 14.4V 900W x 1
at 2 ohm 2300W x 1
at 1 ohm 5000W x 1
at 1 ohm 16V 6000W x 1
at 1 ohm 18V 7300W x 1
Input Sensitivity 6V~0.2V
Low Pass Filter Switchable
( @ 24 dB Slope) Variable Hz 35~250
Subsonic Filter Switchable
( @ 24dB slope ) Variable Hz 10~50
Bass Boost Variable dB 0-9dB
Frequency Response Hz 15-270
Signal to Noise Ratio dB 100
Damping factor 150<
Efficiency @ 4ohm % Over 90%
THD @ 4ohms Less than 0.1%
Fuse Rating 500 Amps
Linked Fuse Rating 1000 Amps
Indicator Power Yes
Protection Yes
Clip Yes
Speaker & Power terminal Mold Type Yes
Power Gauge 0Ga
Heatsink Length inch/mm 25.59"/650mm
Heatsink Width inch/mm 9.38"/66mm
Heatsink Height inch/mm 2.35"/59.6mm
03-03-2011, 05:27 PM
The new DC audio 5k amp
03-03-2011, 08:07 PM
GTFO.
Someone's on to me.
03-03-2011, 08:33 PM
Crap I was gonna guess lightning audio.. close right?
03-03-2011, 09:05 PM
Well... It was between Lightening Audio, DC Audio, and something from the XPlod line. Hopefully I don't regret my decision when the build's finished.
03-03-2011, 09:45 PM
Xplod as in Sony lol deff would of regretted it!
03-03-2011, 10:02 PM
Holy crap, 500 Amp fuse rating, you could probably weld with that thing
03-04-2011, 10:22 AM
sony xplod series is terrible sony should have just stayed with home audio. That DC audio amp is sweet how many ohms are u going to run it.
![[SIGPIC]](image.php?s=faf21057888ec4cd0e702ce96f73fb9a&u=6730&type=sigpic&dateline=1339718145)
03-04-2011, 11:47 AM
Haha thanks man. I won't have the $450.00 to drop on the Mechman Alt. I want anytime soon, so for now, I'll be running 3 to 4 group 31 batteries. Because of this, I'm just gonna run at 1-ohm. Typically I would drop to .5 or .7 to compensate for whatever impedance rise I may have in trying to squeeze the amps full potential. But in this case, i'm gonna use my head and recognize that I am going to have some voltage drop, and not let it get to the point of dropping to 11 volts and clip my equipment.
The subs are 98% decided at this point. My goal is to have the loudest daily driven ground-pounding Alero that I know of. At least on the site would be nice. lol I am aware that a few members here have done 150's etc, but not below 35Hz that I am again aware of. Props to them for sure, but if I wanted a 150, I could do an spl build and get it. But for a daily car that I drive to class everyday, doing a 146-148ish at 30-34Hz, I like that.
I have the materials, just have to apply them!
03-04-2011, 12:06 PM
well i am looking forward to the build.
03-04-2011, 01:49 PM
you wouldnt have been disappointed with Lightning Audio either tho.
03-04-2011, 01:55 PM
I've used a cheap lightning audio amp, and it worked just fine.  Also used their sub for my corolla. Sounded pretty good for the money.
03-04-2011, 07:38 PM
:O i was lookin at that amp!!! eff lol beat me too it!!! im so excited for summer i wanna get this thing metered!!!! and then rip it all out and put in my wall
but i beat you to the mechman  its amazing while driving but the idle is poor!! even tho i got the overdrive pully youll need to tune the pcm to raise your idle to 750rpm not 660 grrrrr lol
but cant wait to see this baby in action!!!! videos mofo!!
parts so far: 10000k hid heads and fogs, alpine INAW900, bluetooth, backup camera, alpine mrp-m2000, 18fi btl, 270amp mechman alterntor, 2 Redtop Batt's, all LED lights and color changing signals white/amber (every bulb other then dummy lights) and limo back 3 and 20% in the front and tinted tails
check out my car http://www.youtube.com/user/scott192
Well I know my car is female because she was bleeding for 7 days and didnt die!
