06-01-2004, 04:02 PM
Ok so my locks are acting really strange. First, it started that I could lock all the doors except for the drivers door. And all doors unlocked fine. I replaced both the front door lock switches thinking there was a problem with one of them.
Now, my doors will all unlock but none of them will lock now. issed: The relays don't even click when I try to lock the doors. It doesn't work with either the remote entry keyfob or the door switches. Talk about annoying. I have to now manually lock all my doors. Any ideas?
06-01-2004, 04:11 PM
Did you try replacing the relays?
06-01-2004, 06:30 PM
I replaced the two door unlock relays but not the lock ones. I have switched them around as I assume they are all the same.
Another thing I forgot two was that it started happening around the time I installed my 4 channel alpine amp. About a week after maybe. I have checked all the fuses. My amp is connected directly to the battery. I was thinking a short. I am going to get all new relays and try that. I'm just running out of ideas. Oh and the relays I replaced were used from a buddies alero.
06-01-2004, 06:42 PM
Oops, I messed up my original post. The first thing that happen was that I could lock all the doors but not unlock the doors except the drivers door. Thats why I tried replacing the unlock relays and switches. But then they would all unlock and then non of them lock. I guess its driving me to drink....
06-01-2004, 09:31 PM
If the relay's don't fix it, it could be a bad BCM. The (body Control Module) controls all of the functions such as the lights, locks, Anti-theft, gauges, Ect. So that could be what is causing the lock issue.
2005 Honda CR-V AWD
06-01-2004, 10:46 PM
Interesting...didn't know that. Where is this part located and about how much are they to replace? Thanks for info! :thumbsup:
06-02-2004, 01:33 AM
this is also another exact problem that i am having. Let me know how it goes.
<img src=\'http://img55.photobucket.com/albums/v167/chochie21/banner.gif\' border=\'0\' alt=\'user posted image\' />
06-02-2004, 07:56 AM
Originally posted by mdodgealero+Jun 1 2004, 09:46 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (mdodgealero @ Jun 1 2004, 09:46 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-brsexton@Jun 1 2004, 09:31 PM
Interesting...didn't know that. Where is this part located and about how much are they to replace? Thanks for info! :thumbsup: [/b][/quote]
Well, its located behind the glove box up in under the dash. It is just a black box with 3 plugs going into it. I'm not sure on how much it cost, but I am very sure its expensive.
2005 Honda CR-V AWD
06-02-2004, 06:36 PM
Originally posted by brsexton+Jun 2 2004, 06:56 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (brsexton @ Jun 2 2004, 06:56 AM)</td></tr><tr><td id='QUOTE'>
Well, its located behind the glove box up in under the dash. It is just a black box with 3 plugs going into it. I'm not sure on how much it cost, but I am very sure its expensive. [/b][/quote]
aahhh CRAP!!!!!
06-03-2004, 08:38 AM
I've heard some talk in other forums online about "resetting the bcm"? Is this possible? If so it might be worth a try to solving these lock problems. Aside from unplugging it and plugging it back in, I wouldn't know how to go about trying it though.
06-05-2004, 11:02 PM
......bump.........no one heard of this huh :unsure:
06-25-2004, 07:29 PM
Not that anyone still cares but.....I fixed my lock problem....woohoo
It was a stupid relay.....a managed to get two bad ones when I replaced them the first time....went to advance auto parts..got one for 10 bucks and PRESTO...good as new
09-29-2004, 06:35 PM
okay, so the infamous bcm problem has possibly struck me.....while driving, the locks will lock when i step on the brake(only sometimes) and just normal driving they will also lock...even though they are lready locked..and then the dome light will not go off when i shut the car off, i had to disconnect the battery
any ideas??....price??? for the bcm
OCA Alero Chapter Member!!!!
ALERO-LESS
09-29-2004, 07:04 PM
I bet yours is the door switch. Check that.
2005 Honda CR-V AWD
