07-16-2008, 08:53 PM
blower motor resistor?
im having trouble with my a/c and i wanted to know if anybody knew where the blower motor/resistor is?
pics would be great but not needed
thanks for the help guys
00 alero
so far: jvc cd player, sony xplod speakers, jl 1000/1 amp
2 12" kicker cvr, wai, green underglow
coming soon: some led's, better subs
07-16-2008, 08:58 PM
i'm pretty sure there is a how-to, online for this.... at least, there used to be.
i think its behind the glove box.
07-16-2008, 09:41 PM
on vacation
the search bar is your friend.
WILL NEVER FORGET
07-16-2008, 11:01 PM
Let's Play Army!
it is behind the radio and the best way to get to it is to remove the glove box. there is a how-to, but it's late and I can't be effed right now to look for it. if you haven't found it in the morning, I'll look around.
Originally Posted by black
07-17-2008, 03:45 AM
^^ No it's on the blower motor which is down under the glove box.
Yiou don't have to remove the glove box to change the resistor. It's in the front bottom of the motor agaisnt the firewall. I forget the size socket, but get an old pillow and put that over the door jam when you lay over it. Trust me
07-17-2008, 06:51 AM
Let's Play Army!
I wouldn't lie...but I am mistaken.
Thanks to Molson for these instructions:
1) Resistor is located next to firewall on passenger side, in part of the blower motor plastic housing assembly, on the downside part of the assembly that is toward the passenger's feet.
2) To get to it, you will need a 7/32 " socket. You will need a universal socket adapter. Trust me... you will need a universal socket adapter.
3) You will need to either be skinny, or hire a ten year old boy who can work tools and can bend his spine funny. (Actually, you can do it). You will need to open the passenger door, and lay on your left hip with your upper torso on the passenger floor.
4) Look up toward the fire wall. LOOK UP! You will see wires feeding the resistor via a connector. You will see two bolts holding the resistor in the housing.
5) Bingo! There you are!
Part #: 15359314
07-17-2008, 11:23 AM
haha thanks guys...i did try the search bar but maybe i spelled something wrong
00 alero
