Yeah the door unlock problem is usually a failing relay. But If all of these things are failing at once It can sometimes be caused by Junk in the fuse box.
Check your fuse box on your drivers side, AND Passengers side for any kind of rust or corrosion. Maybe take out a few fuses and see if they are blown. Make sure to look at them very closely.
If you do see alot of white substance, or rust That will definately cause the problem.
Welcome to my sig.
