05-09-2006, 11:54 AM
would it be worth my time to take off the ac compresser and condenser ect,, off of my car, or would i be wasting my time? :heehee:
05-09-2006, 01:26 PM
Other than reducing weight....no.
If you still wanna do it, let me know, i will tell you how.
05-09-2006, 01:28 PM
[boosted 2.4L]
it only affects you at low speeds if you have it on. if you're on the high way, it will not effect anything. kind of worthless.
05-09-2006, 01:31 PM
watched a deal on mythbusters about windows vs a/c. they concluded that upto about 55-60 mph, the windows is the best option for fuel economy and 55 and over, the a/c is the best. so why would you want to cut them off?
05-09-2006, 01:50 PM
I took mine out, the clutch was toasted and it was cheaper to bypass it than replace the compressor. Why replace something i dont use?
05-09-2006, 02:20 PM
hmmmm i NEVER use my a/c.... and when i drive, i only have my window cracked a lil..... coupe is it a long process to take it out? and how much weight reduction are we talking?
05-09-2006, 02:22 PM
a few pounds
05-09-2006, 05:15 PM
Way more than a few pounds, the compressor itself weighs at least 5 lbs. Then all the lines and what not.
Now i havent actually taken it out yet but i did bypass it.
You need a gator back belt, Belt size- 4060610
6pk1550
Then take out the idler pully and take it to autozone and buy a ribbed one the same size and replace it with that.
Then putting the belt back on:
Your belt will go around alt, over p.s. under water pump, then down to the crank.Then istead of going around the A/C your gonna go straight up around tensioner back to the alt.
05-09-2006, 09:04 PM
at wide open throttle it turns off, and its only uses maybe 2-4 hp
03-09-2012, 08:00 PM
2.4l ac delete..... what is the best way? Bypass pully or just taking it off an using a shorter belt.... help
03-09-2012, 10:08 PM
the Doorman pulley will keep it nice and simple. Makes buying belts easy...lol
03-10-2012, 12:10 AM
either way works, i prefer the replacement stock size pulley setup.
03-11-2012, 07:37 AM
What size belt is it with out the pully or ac? Ill just delete the hole thing.
Reason: just becuz
