Closed Thread
Old 09-21-2011, 08:17 PM   #1
Engine Mechanical Specifications
NOT COMPLETED / WILL FINISH LATER
General
Engine: 60* V-6
Displacement: 3.4 Liters 207 Cubic Inches
Vin Code: E
Bore: 92mm / 3.62 in
Stroke: 84mm / 3.31 inches
Compression Ratio: 9.5:1
Firing Order: 1-2-3-4-5-6
Oil Pressure (Warm): 15 psi @ 1100 RPMs ( 103 kPa )
Cylinder Bore
Diameter: 92.019-92.037mm / 3.6228-3.6235in
Out of round max: 0.007mm / 0.0003in
Taper - Trust Side max: 0.010mm / 0.0004in
Piston
Diameter-Gauged on the skirt 13 mm (0.51 in) below the centerline of the piston bore: 91.970-91.988mm / 3.6209-3.6216in
Clearance: 0.032-0.068mm / 0.0013-0.0027in
Pin bore: 23.006-23.013mm 0.9057-0.9060in
Piston Ring
Top Grove Side Clearance: 0.04-0.075mm / 0.002-0.0033in
Second Grove Side Clearance: 0.04-0.09mm / 0.002-0.0035mm
Top Ring Gap: 0.15-0.36mm / 0.006-0.014in
Second Ring Gap: 0.48-0.74mm / 0.0197-0.0280in
Oil Ring Groove Clearence: 0.48-0.20mm / 0.008in
Gap with segment at 92mm: 0.25-0.75mm / 0.0098-0.05in
Redog is offline
Closed Thread
