11-25-2010, 01:43 PM
yet another mod
Did a little mod last night, got a set of needles from a 98 passat and they fit my aleros guage cluster quite nicely
11-25-2010, 03:14 PM
11-25-2010, 03:58 PM
15.65 @ 87.3 MPH
Good work, looks nice.
11-25-2010, 08:47 PM
wow, perfect. i really want a set of those. i'f you have another or anything
11-26-2010, 07:22 PM
Looks good man. I like it.
11-26-2010, 07:36 PM
not bad.... not bad at all
01-05-2011, 12:34 AM
hmm..good to know,,but whats up with the ses light, and oil light...cmon dude..lets fix these things to keep you on the road!
OCA Alero Chapter Member!!!!
ALERO-LESS
01-05-2011, 12:42 AM
notice car isn't running
01-05-2011, 01:22 AM
those lights would not be on if they werent supposed to be...highly doubt the owner would wait till all lights are out to take a pic to show off the needles
ALERO-LESS
01-05-2011, 04:35 AM
I like a lot
01-05-2011, 02:01 PM
If you put it to key on, engine off those lights all come on. oil cause there's no oil pressure(obviously), and SES because of no oil pressure.
1987 Honda Rebel 450
01-05-2011, 07:34 PM
yea i just turned the key to the on position so the dash lights would come on ( i modded the dash lights to come on with the key because thire hard to see with my dark tint) but the ses light is aways on when the car is running its the rear o2 sensor, just havent fixed that yet.
01-05-2011, 07:48 PM
this is what i got. took them out of a 2000 something cougar. idk why the spedo floats at 15 mph but it zeros out with key on and they all work (and yes the speedo does read correctly when driving)
01-05-2011, 08:28 PM
i was gunna go with the couger ones but found the passat ones and i thing they look a but nicer,
you have needle float because of the counter weights in the needles wernt designed for the aleros cluster, i have a simular issue with my tach. when i hit a bump the needle will dip 4 or 5 hundred rpm then go back to normal
01-05-2011, 09:12 PM
[quote=jawa;571037]i was gunna go with the couger ones but found the passat ones and i thing they look a but nicer,
you have needle float because of the counter weights in the needles wernt designed for the aleros cluster, i have a simular issue with my tach. when i hit a bump the needle will dip 4 or 5 hundred rpm then go back to normal[/QUOTE ]
kinda figured thats what it was. weird mine dont do that at all.
01-05-2011, 09:30 PM
its only my tach that does it im thinkn weaker moter then the speedo or sumthn
10-14-2013, 03:42 AM
not trying to be weird by reviving an old thread but how did u get it to where the light is not showing threw the gas and temp needles since the black peice is smaller and light shows threw
2004 olds alero R.I.P 242,500
1995 f-150 5.0v8 5sp 143,xxx(redneck truck)
Now searching for a new Ho!
Originally Posted by Redog
He no crazy, he WIALERO!!
10-14-2013, 08:55 AM
Electrical tape on the back side of the gauge face around the needle
10-14-2013, 02:41 PM
Ok thanks
10-15-2013, 12:17 AM
exactally what i did
