03-02-2013, 02:38 PM
What's this and why is it doing that?
http://www.youtube.com/watch?v=oT1uJ2CAEdI
I've been having issues lately with that part, it seems to be a vacuum line. Pretty much every time I start my car I have to adjust it slightly so air isn't leaked. My RPMs sputter from .5-1k at idle if it is not sealed. Help?
03-02-2013, 03:05 PM
im guessing you are talking about the pcv since there is zipties on it
Originally Posted by Oldsnut
Originally Posted by tipnitty
03-02-2013, 03:11 PM
Yeah, but not where they are, just where it connects in the red box.
03-02-2013, 03:13 PM
ive never seen it connect there, mine reaches around to the back of the motor.
03-02-2013, 03:14 PM
Under the cable bracket on the neck of the upper intake manifold, there is a rubber grommet that can disintegrate over time, you need to check that and replace the rubber elbow at the PCV valve with something that doesn't collapse, or put copper tubing in the elbow. Most any vacuum leak will have a symptom like that.
03-02-2013, 03:43 PM
I've got the cable bracket off and am looking at the connector. How am I supposed to make it stay sealed?
2000 GL3 Alero V6
Green Metallic
03-02-2013, 04:09 PM
There should be a rubber grommet on there....def gonna need one.
03-02-2013, 09:14 PM
holy bigass pics batman
03-03-2013, 02:05 AM
There's a piece missing on there that should seal to the manifold. You just have to replace the whole pipe. It's fairly inexpensive new from GM.
05-01-2022, 05:55 PM
What's that missing piece called?
I think I need one.
