Go Back   Aleromod.com > General Help > Paint and Body Work
Old 01-10-2011, 10:30 PM   #1
MomsAlero
MomsAlero is on a distinguished road
fixing a loose mirror...
i haven't torn into the door at all yet, i wanted to ask before i did...are the side mirrors on these cars able to be tightened? my mom's 01 Alero recently developed a loose mirror on the passenger side. i know they are suppose to be breakaway mirrors but this one is just LOOSE. so, is there a way to adjust tension on mirror or do i just have to replace the entire mirror? any help would be greatly appreciated!
MomsAlero is offline   Reply With Quote
Old 01-10-2011, 10:36 PM   #2
if you got the one with springs in it, I know one of my mirrors had the spring mounts broke.... But you could also check the bolts... Just pull off the tweeter panel and pull out the foam piece. You'll see three bolts. Make sure the nuts are tightened down. Also check the springs and see if any of them are boken off or just came loose. You'll probably need to pull the mirror glass off for that.
Old 01-11-2011, 05:51 PM   #3
MomsAlero
thanks for the reply! how do i go about removing the mirror glass without breaking it? i do have the kind with the springs in it. probably a broken spring mount like you mentioned...
Old 01-11-2011, 06:00 PM   #4
I just grabbed the glass from the bottom and gently pulled out. You can hold on to the top or something with your other hand and just carefully pull it out. It's not to hard.
Old 02-13-2012, 06:10 AM   #5
Jeremyrobert83
Jeremyrobert83's Avatar
Jeremyrobert83 is on a distinguished road
Send a message via MSN to Jeremyrobert83 Send a message via Yahoo to Jeremyrobert83 Send a message via Skype™ to Jeremyrobert83
I don't know if u guys got this fixed yet but seriously I just picked up 2 paint matched electric mirrors for 50 bucks
Jeremyrobert83 is offline   Reply With Quote
Old 02-13-2012, 06:17 AM   #6
This is an old thread from January of last year. I'm hoping he got it fixed. 50 bucks isn't bad! Nice find!
Old 02-13-2012, 07:01 AM   #7
Jeremyrobert83
Thanks... yeah in noticed it I seen the Jan but not the 2010 till it was already poste
Old 02-13-2012, 09:18 PM   #8
^i think chris pretty well covered it.
Old 06-13-2020, 09:06 PM   #9
zzyzzx
zzyzzx's Avatar
I just repaired mine. Yeah the plastic for the mount part breaks.
