Old 07-01-2018, 01:25 AM   #1
Alero5065
Alero5065 is on a distinguished road
Post 99 3.4 5sp questions
Hey I’m new to Alero mods but I was wonder if anyone could tell me what tranys will bolt up and fit in the 99 3.4 GL. I was thinking of takeing one out of a another GM car or truck with 3.4 and trying it but I don’t have the extra money to get it and not have it work lol. I do know by shearching the threads here that an F40 out of a G6 will work but I’m not a big fan of the 6speds. If at all possible I would like to have a 5 or even a 4 speed. Any help or input is greatly appreciated. Thank you in advance - Cody
Alero5065 is offline   Reply With Quote
Old 07-01-2018, 12:43 PM   #2
1970cs
1970cs's Avatar
1970cs is on a distinguished road
The Grand Am ran down the same line and for a little while the malibu classic. They all used 4 speed autos. The V6 got 4t45-e
Pat
1970cs is offline   Reply With Quote
Old 07-01-2018, 01:48 PM   #3
Alero5065
Pat
Thanks a lot Pat for the help but sadly i forgot to mention that it was Standard transmission that i want lol
Old 07-02-2018, 06:30 PM   #4
You need the f23 trans from one of the j body cars from 00-02 that has the 2200 sfi motor, not the ecotec or 2.4 ld9... That's the bell housing that matches the 3400. After that you need a 5 speed alero or grand am to use as a donor car for the clutch pedal, master cylinder, cables, subframe, axles, shifter assembly and console...
If you do a search for the member HEC he did an amazing write up, unfortunately the pictures no longer work...
Old 07-02-2018, 08:39 PM   #5
Alero5065
Thanks and i also heard from another form that a 4 cylinder trans wont handle the power of a v6 engine and that i might have to upgrade the gears of the transmission to make it work just wondering if that's true for all swaps or just some.
Old 07-02-2018, 09:23 PM   #6
My F23 is doing just fine. They're also used in much higher HP applications on j-bodies.
Old 07-02-2018, 11:39 PM   #7
Alero5065
Ok thank you for clearing up
