Old 02-17-2007, 03:09 PM   #1
comanche
comanche is an unknown quantity at this point
Belt pulley squeal
I just put a new (used) 3400 in a 99' Alero
Something with the belts and pulleys has a problem; it doesn't just squeal, it shrieks.
It seems to be coming from the power steering pump, but the same power steering pump didn't squeal on the old engine.
-Belt dressing only fixes the problem for 5-10 minutes
-the same belt and PS pump were on the old engine and they didn't squeal
-all the pulleys appear to be lined up
-no codes thrown, everything works
-new upper idler pulley
Any ideas?
comanche is offline   Reply With Quote
Old 02-17-2007, 03:18 PM   #2
MixtapeMessiah
Southern Fly Boy returns
MixtapeMessiah's Avatar
is ur belt too tight? or too loose?
Old 02-17-2007, 04:42 PM   #3
might need a new belt how many miles u got on the hoe
Old 02-19-2007, 01:43 PM   #4
comanche
105k on the vehicle. The thing is, the belt didn't squeal on the old engine.
Old 02-20-2007, 09:07 AM   #5
comanche
The tension on the belt also seems to be good.
Old 02-20-2007, 10:52 AM   #6
greenbastard
greenbastard's Avatar
greenbastard is an unknown quantity at this point
buy some belt squeal stop that comes in a can. my buddy had the same problem on his Sunbird Z24 and he just held a bar of soap under the belt until it stopped. he did it everyday.
greenbastard is offline   Reply With Quote
Old 02-20-2007, 10:55 AM   #7
comanche
Yeah I used the belt dressing. It only works for a while. As of now it has quieted down a little. I think I'm just going to drive it and see what happens.
