Old 08-04-2006, 08:34 PM   #1
jackal2000
jackal2000's Avatar
RSM vs FFP (pulley talk)
to my knowledge this hasnt been discussed thoroughly. im looking for comments from people who have the RSM crank pulley or the FFP underdrive pulley. which is better????
Old 08-04-2006, 09:14 PM   #2
ihatemygrandamg
Def FFP. RSM isnt an actual ud pulley,just lighter, and it is much more $
I have an FFP,great mod for the money. More off the line power,revs quicker
Old 08-04-2006, 09:23 PM   #3
jackal2000
jackal2000's Avatar
does the stock belt still fit?
Old 08-04-2006, 09:53 PM   #4
I presume you understand that the concept of a true "underdrive" pulley is that it's less drag on the crank from pulley driven accessories, right? Such as A/C, power steering, water pump, tensioner and idler pulleys, and alternator. Benefit is not only less drag on the motor, but at high RPM's it will also prevent your water pump from cavitating.
Personally, the lightened pulley from RSM will let you rev a little bit faster, but the smaller diameter of the underdrive pulley from FFP will do even better for less money.
Old 08-04-2006, 10:13 PM   #5
jackal2000
jackal2000's Avatar
yes i understand that. what about the belt?? stock or a different size?
Old 08-05-2006, 01:11 AM   #6
I'd say if the pulley is smaller, you will need a smaller belt.
I have the RSM pulley and I like it, I also have a lightened water pump and the alt pulley too, but that isn't the in the car right now
Old 08-05-2006, 02:03 PM   #7
what I would do is contact FFP and ask them. Tell them what application you have. Simple.
Old 08-05-2006, 02:19 PM   #8
Brycesdad
Brycesdad's Avatar
Brycesdad is an unknown quantity at this point
Send a message via MSN to Brycesdad Send a message via Yahoo to Brycesdad
doesn't unorthadox make an underdrive pulley for the alero? if so how does it compare to the RSM and the FFP?
<a href=\'http://www.cardomain.com/ride/2314136\' target=\'_blank\'>My Cardomain</a>
<a href=\'http://emperildesigns.com\' target=\'_blank\'>Tha Club</a>
Were looking for people to join.
Brycesdad is offline   Reply With Quote
Old 08-05-2006, 02:23 PM   #9
yes, they do, it's for the 2.3/2.4, not for the 3400 V6.
jackal2000 is in the V6 category, as is this thread.
Old 08-06-2006, 07:29 AM   #10
-Alero-
-Alero-'s Avatar
i got the FFP pulley, it requires a 1 inch shorter belt.
fairly simple install. i believe someone a long time ago (springsfastestalero) said that the FFP pully was better because it acted more as a dampener which was healthier for your motor in the long run, because the RSM one is just a light pulley, with little to no dampening.
AUTOBOT
Old 08-08-2006, 05:40 PM   #11
projectalero
Can anybody tell me if the FFP pulley kit is just the crank pulley or does it come with the accesory pulleys as well?
Old 08-08-2006, 05:42 PM   #12
jackal2000
jackal2000's Avatar
its just the crank pulley
here's the link for anyone interested. they ship fast too. i should have mine the 10th.
www.fastfwdperformance.com
Old 01-08-2007, 12:55 PM   #13
bratch15
bratch15's Avatar
bratch15 is on a distinguished road
hey jackal or -Alero-, I am running a sound system that runs at 800 RMS 1600 Watts max, and I was wondering if the FFP pulley will hurt my alternator....
2004 3.4L Alero GL, CAI, Clear Corners, Reverse Glow Gauges, Alpine headunit w/Audiobahn subs and amp
http://www.cardomain.com/ride/2538269
bratch15 is offline   Reply With Quote
Old 01-08-2007, 12:57 PM   #14
bratch15
bratch15's Avatar
Also, when you ordered your new belt, how did you go about figuring out which belt you needed. If you know which belt exactly it is, I would be very happy if you could share that info...
Old 01-08-2007, 01:16 PM   #15
jackal2000
jackal2000's Avatar
i run 3 12's and 2 amps and the pulley didnt make that big a difference but because of my camshaft my car idles higher than yours so i guess i am the wrong person to give advice on that subject. as far the belt, the goodyear part number is 4060855. however, goodyear is somewhat hard to find unless you order online but give that number to the parts guy at any auto store and they can cross reference for one they have in stock.
Old 01-08-2007, 02:18 PM   #16
bratch15
bratch15's Avatar
Aight thanks. Will the pulley bring up any codes from the computer after the installation?
Old 01-08-2007, 02:19 PM   #17
bratch15
bratch15's Avatar
Also does anyone have a FFP pulley they are looking to sell?
Old 01-08-2007, 02:34 PM   #18
bratch15
bratch15's Avatar
Not to be a pain with these questions, but which underdrive pulley did you purchase from FFP. There is two pulleys for the 3.4 DOHC for different year cars. Which one did you purchase or does it matter which one?
Old 01-08-2007, 02:56 PM   #19
jackal2000
jackal2000's Avatar
its the 3rd one down the list
'88 - '05
2.8, 3.1 MPFI and 3100, 3400 SFI
$109.99
you shouldnt have any codes, but if your SES light does come on you will need a crank case learn. they suggest disconnecting the battery for 24hrs to see if that fixes it first.
Old 01-08-2007, 08:57 PM   #20
alerored04
alerored04's Avatar
jackal is right, if it throws a code you will need a crank or what gm calls a C.A.S.E. learn, any dealership will do it and it normally runs about $30. I havent heard of many needing that though. One thing to remind you of though, you need to transfer the 24x sensor ring from the back of the stock pulley onto the new one, its not hard, just 3 little screws and a bit of anti sieze. The ffp will come with directions on this. and alero is correct it is a 1" shorter belt. I have 2 500 rms 1000 peak amps with the ud pulley with no issues, have had the pulley on for 2 years now.
My car breaks alot.
