10-23-2012, 02:27 PM
handbrake light
title says alot lol i start the car take handbrake down light goes away , then 1 bump and it lights up in the dash :s where should i look for a fix
10-23-2012, 03:00 PM
just the ebrake light? if so could be a bad sensor.
Originally Posted by Oldsnut
Originally Posted by tipnitty
10-23-2012, 03:21 PM
yup ding ding ding that damn buzzer stress me much hahah yes only light all is worrking good my alero is a bitc h really i got like all the lights on in the dash but run so smooth xD hehe abs /check engine / service engine / change oil / ebrake/ trac.off ^^ ballin all the lights here
service engine / abs / trac.off is due to me cuting the wire off my wheel bearing o.O haha
change oil .. careless
check engine i get 2 codes wich i dont remember numbers but are related with my catalyser
and ebrake now needs to be gone !
10-23-2012, 03:22 PM
wheel bearing. boom. my car used to do that. or you are running low on brake fluid
10-23-2012, 03:36 PM
check your brake fluid for the ebrake light.
fix your wheel hub.
10-23-2012, 03:42 PM
cant fix my wheel hub i cut the wire at hub would require me to open the hub and rewire o.O rofl thanks will be lookin at fluid in like 20 mins
10-23-2012, 04:02 PM
ok just checked out and all my liquid are full !! need another spot to look up ! ^^
10-23-2012, 04:05 PM
replace the wheel hub, and it could be a bad ebrake sensory then...
10-23-2012, 04:10 PM
where is the sensor at ? rear wheel hub ?
10-23-2012, 04:54 PM
replace the one you have cut the wires on.
im not to certain on the ebrake cable sensor...... someone around here should know.
10-23-2012, 05:35 PM
cool , well for the bearing i dont care much as i always used to trac off every single time i leave with the car so i figured i cut the wire prevent me from pressin the buton ^^
