11-10-2012, 11:24 PM
tire sizes
Hi right now I have 205/55/16 I have on my car and it looks a bit small so I tried 225/60/18s and it rubbed I would like to run 18 inch rims on my car but what's the ideal tire size
2003 alero 2.2 ecotec tinted windows, cold air intake, strut bar, full pacesetter exhaust, HID lights, grill mesh, brembro brakes, kicker l7, chipped and more but looking for more mods i would like to keep my car luxury, clean and a head turner.
i do auto detailing so my car is always spotless [SIGPIC]
11-10-2012, 11:40 PM
I can't specifically answer this as I don't know but I know one of the first questions you will be asked is the offset of your 18's
11-10-2012, 11:50 PM
if you want to keep you speedometer accurate, you will have to keep the ratios the same... meaning if you go up 2" in rim diameter, you need to drop 20mm from tire size... thus said, depending on the size of the rim, the width of the actual tire does effect the size of the sidewall as well... you could run a 225/40/18, or you could get away with a 245/35/18 etc.
best bet is to use a rim/tire conversion calculator...
11-11-2012, 09:48 PM
I just went to tirerack.com to get my wheel/tire combo. That way I knew I got exactly what I needed for my car. If anything just add your cars info there and see what it recommends for you based on rim size and take that information elsewhere.
11-12-2012, 01:11 AM
I'm running 215/45/18 tires on my car and they don't rub on stock suspension or after I installed the lowering springs
11-12-2012, 10:07 AM
The ideal tire sizes are the OEM sizes.
11-12-2012, 10:41 PM
Nawwwwwwww
11-12-2012, 11:00 PM
Nawwwwwwww
lol so true... even gm couldn't make up their minds with what size to put on the car... 15's or 16's... hell, let's just use both!
11-13-2012, 09:23 PM
225/45/17
225/40/18
11-13-2012, 10:16 PM
Originally Posted by Redog
225/50/16
225/45/17
225/40/18
265/35/17 yummmmmm
11-14-2012, 05:51 AM
ive got 225/40/18
Originally Posted by Oldsnut
Originally Posted by tipnitty
11-14-2012, 06:29 PM
255/60/15's on the back of my Delta. Soooooooo wide
11-15-2012, 08:29 AM
255/30ZR19 on all 4 corners... it's perfect!
11-15-2012, 10:35 AM
You must spend a small fortune on tires.....especially with your power level.
11-15-2012, 01:32 PM
I have 245/40/18 tires
11-16-2012, 11:29 AM
LOL THEY ARE EXPENSIVE!!! but I don't drive it much.. in fact it hasn't moved since about a year and a half (since it got keyed)...
she is there, patiently waiting me in my garage...
