Old 02-03-2007, 06:42 PM   #1
redrider07
redrider07's Avatar
redrider07 is on a distinguished road
TPS enhancer?
Do you guys think that this would really do anything. I am talking about the throttle position sensor enhancer from www.pfyc.com. It claims that as you hit 70 percent throttle, it tricks the computer into thinking that you are at 100 percent throttle......so maybe quicker acceleration?
link...... http://www.pfyc.com/pc/GA3003/ALUNDE...+Enhancer.html
redrider07 is offline   Reply With Quote
Old 02-03-2007, 06:48 PM   #2
jabartram
AutoCross Alero
jabartram's Avatar
read this.
http://www.aleromod.com/forums/showt...light=enhancer
Old 02-03-2007, 10:01 PM   #3
more fuel without the extra air = rich condition = bad mpg = no noticeable difference except a higher gasoline bill.
Old 02-14-2007, 05:19 PM   #4
Jferg2223
Jferg2223's Avatar
Jferg2223 is on a distinguished road
I own this and I definately wouldnt waste your money. First of all it does make a difference but its barely noticeable through mid second and early third gear. Sometimes if the enhancer gets too hot and you stop your car it will idle around 3400 rpm. It doesnt work with aftermarket pcm because for some reason I push the gas down and it does nothing but if i double pump it the throttle kicks in.
Jferg2223 is offline   Reply With Quote
