Old 01-31-2012, 10:28 PM   #1
jhubbz
⌘ Irish Pride
jhubbz's Avatar
Weird vibration noise
I can't quite figure out what this is. I can start noticing it around 30 mph as a low hum and starts to get more high pitched as I gain speed up to 70 mph. It's not the road I'm on since it happens everywhere. I have basically brand new tires and they're not under-inflated. It seems to be coming from the front driver-side wheel. Also of note, it makes more noise when turning at those speeds.
I was at about 70, then slowed to about 55, then sped back up to 70. Ignore the sideways shot, as it was just intended to get the sound.
Anyone have any idea what this could be???
Done lost my mind
Old 01-31-2012, 10:31 PM   #2
I would wait for someone else to respond but I am gonna have to guess wheel bearing so you are gonna need a new hub
Old 01-31-2012, 10:37 PM   #3
does it also make grinding sound also. because when my wheel bearings went i started to have a grinding sound and the abs and trac off light would come on.
Old 01-31-2012, 10:47 PM   #4
let me guess, this only started happening when you got new tires
Old 02-01-2012, 07:01 AM   #5
guiguilandry
guiguilandry's Avatar
I vote for the Bearing...
Custom or Nothing...
www.demonautosport.ca
Old 02-01-2012, 07:25 AM   #6
sounds like a hub to me. if you swerve left and right (putting more weight on one bearing and then the other) should drasticly change the noise.
Old 02-01-2012, 08:08 AM   #7
jhubbz
⌘ Irish Pride
jhubbz's Avatar
No, I've had these tires since September.
Yeah, the sound definitely intensifies.
Done lost my mind
Old 02-01-2012, 08:29 AM   #8
then hub for sure
Old 02-01-2012, 09:11 AM   #9
lift the car up and put your hands at 6/12 oclock. push in and out (top then bottom then top etc) if theres play thne that hub is shot.
Old 02-01-2012, 09:20 AM   #10
Hub
Old 02-01-2012, 09:22 AM   #11
falloutboy
falloutboy's Avatar
I say hubs, too.
Thanks
Julian
1995 Chrysler Stratus LX
2002 Nissan Primera with CVT
Old 02-02-2012, 09:19 AM   #12
jhubbz
⌘ Irish Pride
jhubbz's Avatar
Thanks guys, I bought a new hub assembly yesterday. Will put it on when I have some time this weekend. Does anyone recommend I rent a hub puller?
Done lost my mind
Old 02-02-2012, 12:31 PM   #13
BHF. the universal hub pullar.
Old 02-05-2012, 11:59 AM   #14
jhubbz
⌘ Irish Pride
jhubbz's Avatar
So I replaced the hub yesterday, but it still makes the dang noise!! Could it be the CV joint? I had an older integra before that I had to replace the CV joint on bc it would go click click click when I turned.
Done lost my mind
Old 02-05-2012, 01:58 PM   #15
which hub did you replace?
Old 02-05-2012, 02:02 PM   #16
Philbar71
Sounds odd.
Something to check, alignment too. My car was way out of alignment and the tires made a strange noise similar to that, except only at about 50mph. Once it was aligned, the noise went away pretty much.
Old 02-05-2012, 02:34 PM   #17
jhubbz
⌘ Irish Pride
jhubbz's Avatar
Front driver. I'm almost positive that's where the sound was coming from. it wouldn't make sense for the back to be bad since it gets more intense when I turn. I might try and do the other side later, probably needs it anyway.
Originally Posted by Philbar71 View Post
Sounds odd.
Yea I should get it checked out. I didn't want to do it til I got it lowered, but I might have to.
Done lost my mind
Old 02-05-2012, 02:49 PM   #18
one way to find out if its the tires is to rotate the tires front to back. if the noise changes and moves with the tires then its the tires.
usually if its a bearing and you make a left hand turn (turning left) and the noise gets louder then its the right bearing bad. if you make a right turn and the noise gets louder its typically the left bearing. when you lift the vihicle grab the wheel and 6 and 12 and npush in and out alternating top and bottom, if you have play its your bearing. at work iv also run vehicles on the lifts and had somone walk around it to found out which side the noise is coiming from.
Old 02-05-2012, 06:05 PM   #19
jhubbz
⌘ Irish Pride
jhubbz's Avatar
yea, when i turn right, it makes more noise. and I checked the 6 and 12 thing on the original bearing and it had a very slight amount of play. I will change the tires front to back possibly tomorrow and see. Thanks for all your insight.
Done lost my mind
Old 02-06-2012, 07:58 AM   #20
jhubbz
⌘ Irish Pride
jhubbz's Avatar
Well, SVS, anti-lock and trac off lit up on my commute this morning.
Done lost my mind
