My A/C all of the sudden stopped working on the regular modes. It will only work if I crank it up to the maximum setting. Once I crank it up, it works fine and I get cold air. Anybody seen this before?
A/C only? Is it the fan that doesn't work until in the highest setting? If so, it may be the fan resistor. Had to replace mine a couple of months ago because it only worked in the highest setting. The resistor is about twenty bucks and is behind/under your glove box. Pretty easy to get to.
I j ust replaced the resistor and it works like a champ. My dealership raped me for 27 dollars for it. Interestingly enough, the old one was made in Mexico and the new one is made in Japan.
