05-05-2009, 12:30 AM
SOHC Quad...single cam performance!
Yeah right
maybe for good gas mileage.
Well I finally got my Quad together. Feels dam good. With some help from my best friend I got it done in no time
086 decked head installed with stainless steel valves & H.O. valve springs
H.O. Camshafts w/ pulley
and of coarse built internals with other goodies.
05-05-2009, 12:36 AM
hehe 40s, looks good though, how much did u drop on the powdercoating?
05-05-2009, 12:39 AM
Canada's Ghost
hope it performs as good as it looks.
05-05-2009, 12:43 AM
powder coating was $120...but thats from last when I first rebuilt the motor. I had a leaking valve after an issue and now I had to rebuild it again.
So I swapped cams and heads thus I had to powder coat the new cam carriers. Another $80 just for the cam carriers...price had increased since then due to the economy.
Oh and I have a 24, my boy has a 40
05-05-2009, 03:14 AM
Sweet engine. I hope you get it to work right this time so you can enjoy it!
05-05-2009, 03:43 AM
Looks nice. Brew helps too
05-05-2009, 04:42 AM
New and Improved
you two look scary. I would think twice before beauting you two up engine is looking incredible as aweosme, keep us updated for sure.
05-05-2009, 08:10 AM
Your buddy has good taste in booze.
Engine looks nice, but I think it would look better in the car.
GX Coupe
Dropped and Blown
05-05-2009, 08:40 AM
The Drunk
Wow I haven't seen a latino holding a Mickey's since I lived n PA and we ran outta MD20/20 and everything else.
`03 Alero GL 2.2L Ecotec
05-05-2009, 09:06 AM
New and Improved
haha oh mickeys....
05-05-2009, 09:55 AM
because you'd wake up in an alley somewhere, which is probably nothing new
05-05-2009, 09:56 AM
New and Improved
please. I back down from no fight. And as for waking up in strange places, eh. Read my write-up on my weekend and youll understand.
05-05-2009, 01:01 PM
It worked perfect last time.....I was driving it for over 4 months. Then I got tired of seeing the PCV hose connected to a small breather filter.
I hooked it up after the t-body instead of before and thats when it all went wrong. I should have knew better.
05-05-2009, 01:20 PM
New and Improved
I hooked it up after the t-body instead of before and thats when it all went wrong. I should have known better.
Haha. Looking good man. Plans for boost in the future I take it?
05-05-2009, 01:52 PM
Raging Alero-Holic!!
Yeah....my grandpa used to drink mickey's when he did work in the garage too.....by the way,that engine looks clean as all get out!keep up the good work and im trying to do my engine like that as well
2000 Olds Alero GL2 Coupe.........Cleared Front Corners, SP 8000k HID's,WAI,2.25 Custom Imco Performance Exhaust,Intrax Lowering Springs,18x8.5 inch Quantum Tek QT 104 Wheels,R1 Concepts Drilled/Slotted Rotors
05-05-2009, 02:06 PM
5 lbs. of boost with the high compression from the 086 would be PERFECT!
05-05-2009, 02:07 PM
New and Improved
agreed
05-05-2009, 02:09 PM
Gone but not forgotten
looks real gewwd.....
05-05-2009, 03:52 PM
that is a sexy bitch of a motor.. and kickin back drinkin and wrenchin is the way to go man +1
2001 Oldsmobile Alero GL Sedan LA1 3400 SFI V6
Nickname : Midnyte
05-07-2009, 03:38 AM
Boost Guru
5 lbs of boost from what?
Screw that, run a 3076R and crank the boost controller. Yeah it's a high compression head, but with low compression pistons. Just spray a little meth if you need to
