Old 11-04-2008, 07:27 PM   #1
irondiezl3
irondiezl3's Avatar
front liscense frame
i need a new frame in the front. is this possible to replace without taking bumper cover off? body shop said its in with rivets which im assuming means you have to take the cover off to change out? anyone ever try without taking it off?
Old 11-04-2008, 07:30 PM   #2
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
when you get the new one, BREAK the old one off and cut the rivets with bolt cutters (or whatever will work for you) and then put the new one on with license plate screws.
Old 11-04-2008, 08:08 PM   #3
irondiezl3
irondiezl3's Avatar
wtf does a rivet look like?
Old 11-04-2008, 08:26 PM   #4
tank the licence plate off. its little aluminum studs holding the holder to the bumber, should be all there is so its impossible to mistake. if you can break the hlder off without breaking the bumper, do it the way stated. but if not get a drill bit about a size or two smaller than the rivet and drill through it then it should break easily.
Old 11-04-2008, 10:30 PM   #5
AlbinoMonkeyRat
Let's Play Army!
look at the inside of the button on your jeans...THAT is a rivet.
Old 11-04-2008, 10:34 PM   #6
drill into the "center" witha drill the same size as the "hole" it will disconnect and not damage anyhting around it
Old 11-04-2008, 11:11 PM   #7
irondiezl3
irondiezl3's Avatar
man i love this forum thx
Old 11-11-2008, 04:41 PM   #8
irondiezl3
irondiezl3's Avatar
can i screw this new one in instead of rivets?
Old 11-11-2008, 04:49 PM   #9
CactusWill
yes
The message you have entered is too short. Please lengthen your message to at least 5 characters.
ok done
Old 11-11-2008, 05:04 PM   #10
lol, this thread
Old 11-11-2008, 10:55 PM   #11
irondiezl3
irondiezl3's Avatar
ok wtf the screws dont go in? they just go in the hole there nothing to screw in to??
Old 11-11-2008, 11:10 PM   #12
CactusWill
You screw them into the holes. The screws have to be wider than the hole for it to catch the plastic. Fascinating, eh?
Old 11-11-2008, 11:31 PM   #13
or you can use those little plastic pushpins that expand a piece when you push the center in..
Old 11-12-2008, 12:54 AM   #14
irondiezl3
irondiezl3's Avatar
im thinkin there must be sumthin behind the bumper cover that broke off when i drilled out the rivets cuz i got two screws in and the other two go right to the actual metal bumper im gunna have to get some long self tappers.
Old 11-12-2008, 01:07 AM   #15
Old 11-12-2008, 01:14 AM   #16
CactusWill
Dude, don't screw your license plate holder into the frame. Just find the right screws for the bumper cover, or if you messed up the bumper cover than find screws that will fit.
Old 11-12-2008, 10:39 AM   #17
zzyzzx
zzyzzx's Avatar
Mine is screwed into the bumper cover. If you are getting to the metal bumper, than you are doing it wrong or hitting the leftover rivet pieces.
Old 11-12-2008, 07:41 PM   #18
AlbinoMonkeyRat
Let's Play Army!
seriously...there is such a thing as "license plate screws" they are actually wood-boring screws, however, they are short and just wide enough to pass through the holes on the license plate. these will be perfect for what you're doing. So get your butt to the auto parts store and spend $2 to get the right stuff.
Old 11-13-2008, 12:04 PM   #19
zzyzzx
zzyzzx's Avatar
Actually I used #10 stainless steel wood screws, with stainless steel fender washers. I think I used two screws that were 1" long, and two screws that where 1.5" long. IMO, the right stuff for license palte screws is stainless steel, not "whatever an auto parts store has".
Old 11-13-2008, 09:32 PM   #20
AlbinoMonkeyRat
Let's Play Army!
^ good point. if it's not stainless, corrosion/rust of the screws will reek havoc on your bumper, ruining the paint. However, auto parts stores "supposed" to have the right stuff FOR CARS (duh! LOL), so check there first for the stainless steel screws.
Who would have thought a topic about attaching a license plate would be this long? haha
