01-17-2012, 03:52 AM
Cloughed heater core?
Got a call from my buddy again on his way home from work. He had no heat, at all, even with the engine at running/overheated temp. Because if he leaves the heat on, engine temp shoots all the way up, with it off, runs perfectly fine. I'm thinking heater core. Flush should do it right?
01-17-2012, 05:57 AM
A buddy of mine had a similar problem on a 99 2.0 Eclipse. We changed the thermostat, no luck. Then flushed the heater core, some luck with slightly warmer heat, but high temps. Ended up being the head gasket... Idk about your buddy's prob, seeing that his temp shoots up with the heat on because the heat makes the fan turn on which will cool the engine slightly... Good luck!
Current lineup:
-1982 Mercury Capri RS 5.0 302 2V 4sp
-1995 GMC Sierra 2wd 5.0 305 5sp
-1998 Grand Prix GTP Daytona 500 Edition Pace Car
01-17-2012, 05:50 PM
bumpy?
01-17-2012, 07:30 PM
Its Beer Thirty
What motor? Sounds like a headgasket though.
Originally Posted by Daytona
01-17-2012, 08:12 PM
Does not sound like a heater core, engine temperature should drop a little with heat on, not go up.
01-17-2012, 08:37 PM
would this be the same friend that the site diagnosed as having a bad head gasket before?
EDIT: This would be the thread that I am referring to : http://www.aleromod.com/forums/showthread.php?t=35064
01-17-2012, 10:29 PM
^yup. So head gasket? And 3.4... Seeing as how it's posted under said section
01-17-2012, 10:36 PM
Its Beer Thirty
Seeing as I was looking under new posts I didn't notice it was under the 3.4 section.
01-17-2012, 10:41 PM
^you got me there. Sorry, I'm outa nicatine so I'm a little snappy. But the general concincouse is head gasket then?
01-17-2012, 10:53 PM
Its Beer Thirty
I would say headgasket. Even if it was the heater core clogged up a flush wouldn't fix it.
