Old 11-04-2012, 11:57 AM   #1
shawnschuldt
shawnschuldt is on a distinguished road
01 Alero DTC's
Hi everyone im not myself an alero owner but my mother recently became one. now i do all th maintnence on all our cars and i have my own project cars, but im looking for some help with hers.
i have hp tuners and her ses light was on and i pulled the log and there are tons of codes mostly to do with shorted wires and low power circuits. i was wondering if anyone can give me some insight on what might be causing all these.
car runs and drives fine not 1 single thing on the car doesnt operate like its supposed to so these got me stumped.
[Brake] C1245 - (History)
[Unknown] B3138 - (Pending) (Old)
[Unknown] B3128 - (Pending)
[Unknown] B3133 - (Pending) (Old)
[Unknown] B2585 - (Pending) (Old) (Immature)
[Unknown] B2577 - (SES)
[Unknown] B2578 - (SES)
[Unknown] B2587 - (SES)
[Unknown] B2588 - (SES)
[Unknown] B2648 - (SES)
[Unknown] B2600 -
[Unknown] B2601 - (Pending) (Immature)
[Unknown] B2602 -
[Unknown] B2603 - (Pending)
[Unknown] B2542 - (Immature)
[Unknown] B1369 - (Immature)
[Unknown] B1374 - (Old)
[Unknown] B1379 - (Immature)
[Unknown] B2752 - (Old) (Immature)
[Unknown] B2753 - (Immature)
[Unknown] B2948 - Security System Sensor Power CKT High (Old)
[Unknown] B2947 - Security System Sensor Power CKT Low (Immature)
[Unknown] B2957 - Security System Sensor Data Circuit Low (Old) (Immature)
[Unknown] B3033 - Security System Indicates Tamper (Immature)
[Unknown] B3031 - Key Decoder Device in Assem Learn Mode (Pending) (Old)
[Unknown] B1000 - ECU Malfunction (Immature)
[Unknown] B1001 - Option Configuration Error (SES) (Pending)
[Unknown] U1000 - Class 2 Communication Malfunction (Immature)
[Unknown] U1128 - Loss of Communications with IRC (SES) (Pending)
[Unknown] U1096 - Loss of Communications with IPC (Immature)
shawnschuldt is offline   Reply With Quote
Old 11-04-2012, 12:39 PM   #2
[Unknown] B2600 -
[Unknown] B2602 -
Offhand, I would say that the [Unknown] codes are not causing the SES light. HP Tuners is not perfect, in that it records more codes than it needs to, or irrelevant codes. But sometimes it also can pick up more valid codes than some cheaper handheld scanners.
With the SES on, you might run it down to Autozone and have them scan it for a "second opinion." Or, of course, clear the SES and note how fast the codes come back while monitoring it on HP Tuners.
And then, sadly, sometimes the indicated code may be caused by another problem unrelated to the code, because the diagnostic system itself is not perfect.
Old 11-04-2012, 09:04 PM   #3
shawnschuldt
Well the ses light was on from evap small leak i fixed that cleared the codes and this is what comes back instantly.
The light stays off with that one code fixed. Just worried that it migbt be from a failing igniion switch or somethin
Old 11-04-2012, 10:17 PM   #4
Run it and see what happens. Better yet still have an auto parts place look and clear the codes as nessacary to start fresh.
