Old 01-15-2011, 02:57 AM   #1
lowolds1
lowolds1 is on a distinguished road
Exclamation train horns
so i recently installed train horns/ air horns whatever you would like to call it on my alero.(compresser, tank, horns, the whole 9 yards) i know there are a few small leaks, like at the gauge and tank but sometimes when i hit the switch to blow the horns (there are 3 total) one will go a few seconds before the rest kick in. does anyone know why this is or a solution to the problem?
lowolds1 is offline   Reply With Quote
Old 01-15-2011, 03:58 AM   #2
you need to make sure that the air hoses are the same length to each horn from the splitting hub fitting. it only make sense that one horn will sound before the others if the air has less room to travel.
Old 01-15-2011, 10:51 AM   #3
lowolds1
they ony have one line going into the horns. there is a single selenoid on the horns where only one air line goes in the horns are all 3 mounded together
Old 01-15-2011, 06:02 PM   #4
lowolds1
can anyone else help?
Old 01-15-2011, 07:57 PM   #5
Not enough pressure? What psi are you running in the tank?
Old 01-15-2011, 11:30 PM   #6
how can you have one line feeding 3 horns? what type of horns did you buy? if it really if all together like that with 1 inlet port then there is nothing that you can do to prevent it.
Old 01-16-2011, 02:02 AM   #7
lowolds1
around 150 max in the tank, and they are on trainhorns.net its the kracken truck horns kit you can see in the picture on the site how they are grouped into one
Old 01-17-2011, 07:04 AM   #8
Can't really tell, does each horn have a valve on the end? Kinda looks like they do
Old 01-17-2011, 04:24 PM   #9
lowolds1
if you look right above the center of the closest horn to you in the pitcure there is a little cylinder type thing that the airline goes into there is only one stop so idk why its doing it....to cold maybe?
Old 01-17-2011, 04:49 PM   #10
Temp would have nothing to do with it. The only possibly problem is the ones already posted. You have an air leak, or a bad horn/bad horn design
Old 01-17-2011, 05:25 PM   #11
With 150 psi, I'd bet you'd hear a leak. Any way you could take a video of the setup and what it's doing?
Old 01-17-2011, 10:13 PM   #12
undersc0re
undersc0re is on a distinguished road
You probably need more flow, the smaller horn is working because the hole is smaller to make noise, but the larger ones need a while longer of more flow to get going! If your horns are all the same size/frequency then your guess is as good as mine, I would still say you need more constant high flow of air.
undersc0re is offline   Reply With Quote
Old 01-18-2011, 12:53 AM   #13
lowolds1
yeah it doesn't do it as much now i noticed it only does it at certain psi's maybe a wear in period? idk im quite new to air components and i fixed the leaks
