Old 04-22-2006, 09:19 AM   #1
SouthDakotAlero
SouthDakotAlero is an unknown quantity at this point
Does anybody know what the largest width tire I could fit on an 18 x 8 rim is? I don't want to know if it will fit on the car, just if it will fit on the rim.
SouthDakotAlero is offline   Reply With Quote
Old 04-22-2006, 09:42 AM   #2
mfuller
Depends what the aspect ratio of the tire will be.
For instance, if you will be using a 40-series tire, the generally accrepted max tire width is 245mm. 50-series tire you can likely move up to a 255mm tire.
Old 04-22-2006, 10:23 AM   #3
Oldsman
Owner
Oldsman's Avatar
255 would be the widest for 18x8
Beware of the BackStabber
