Old 04-09-2006, 01:24 AM   #1
going for some QA1's for the back. Anybody got a stock unsprung height on springs? Looking to get about 450 spring rate at stock height.
yeah, I know, trip to the dentist coming up, soon as I hit the first bump.
Basically I know alot of ya have put on aftermarket springs and might have a set of stockers to measure for me if you dont mind. Also, I.D. at the perches too please.
Old 04-09-2006, 10:37 PM   #2
really, they're that long, eh?
hmm....out of 25 views on this thread you'd think somebody would have said something. Nobody out there has a set of stock springs to measure (uninstalled) ?
Old 04-09-2006, 10:59 PM   #3
alerored04
alerored04's Avatar
i can check for ya tomorrow, are all four the same, if not how do i recognize the rears so i know i get the right numbers for ya?
My car breaks alot.
Old 04-09-2006, 11:02 PM   #4
ok, I'm not going to tap-dance and look like a fool
Anybody want to help out with volunteering how to tell the difference on front / rear? Or are the both the same?
Old 04-09-2006, 11:02 PM   #5
2fst4u
[boosted 2.4L]
2fst4u's Avatar
rears are skinnier. fronts are fat.
Old 04-09-2006, 11:03 PM   #6
thanks
Old 04-09-2006, 11:08 PM   #7
well, there ya have it, alerored04. If you would be so kind as to measure them when you have a chance, I'd definitely be grateful.
Appreciate it, both of yas.
Old 04-10-2006, 12:04 AM   #8
alerored04
alerored04's Avatar
sure thing man ill take care of it for ya.
My car breaks alot.
Old 04-10-2006, 04:07 PM   #9
alerored04
alerored04's Avatar
Just measured it Blackack, rear springs unsprung, (the skinny one) is 15 1/8" tall.
My car breaks alot.
Old 04-10-2006, 05:01 PM   #10
Fast Eddie
DIAAM you must have a dentist in the family with the rating. I think we figured about 350/300 F/R for a really stiff setup at one point. 450 lb is gonna be like a solid post. On the up side you wont have any of that rear end squat
I'm on a boat.....
Old 04-10-2006, 09:30 PM   #11
thanks alerored, I appreciate that. I know it's alot to ask, but can you also measure the coil diameter at the perch ends, so I can make sure the ones I buy are not to big or small in diameter...
FastEddie, yeah, that's the idea. No squat in back. Basically I've already got the fabrication in progress, but I'll have a reasonable (250 lb) spring rate in the front, and I'm using aircraft cables with pins that I'll insert once I get to the track that will hold the front end down (stop downward travel since we have no snubbers)and keep weight over the front end, and also prevents the CV's from getting out of their normal 90* angle from the tranny. This will prevent torque loss from geometrical changes at the axles, and also from the front end raising and back end squatting.
Old 04-10-2006, 09:40 PM   #12
alerored04
alerored04's Avatar
no prob man, ill check it right now.
My car breaks alot.
Old 04-10-2006, 09:45 PM   #13
alerored04
alerored04's Avatar
just measured it, the perch end (the narrow end, i believe) is 3 5/8" the other end for comparison is 5" even. So you know i measured from the outside of the stock that the spring is made from, so the very outside of the metal to the same spot on the other side.
My car breaks alot.
Old 04-10-2006, 09:52 PM   #14
thanks man, you saved me a whole lot of headache with that. I appreciate you taking the time out to help me.
Old 04-10-2006, 10:53 PM   #15
alerored04
alerored04's Avatar
no problem man, glad i could help out, i figure its a 30 ft walk from my bedroom to the garage and the tape measure is in a drawer on the way, i might as well help out where i can. Im just curious but why are you looking at going stock ride height? more travel? ground clearance? or just easier to get? I was just wondering for curiosities sake.
My car breaks alot.
Old 04-10-2006, 10:57 PM   #16
dropping the front end, keeping the back end stock height. This will force more of the overall weight over the front tires and help with traction. The stiffness of the springs I'm going to use just keeps the back from squatting on launch and causing me to lose traction even more.
Old 04-11-2006, 02:33 AM   #17
alerored04
alerored04's Avatar
ahh ic, that makes sense, thanks for explaining it to me.
My car breaks alot.
Old 04-11-2006, 10:24 AM   #18
Rubered00
Rubered00 is an unknown quantity at this point
Send a message via AIM to Rubered00
Wont this cause you to understeer much easier in any corners that you try to go fast around? I realize that your mainly doing all of this for the drag strip but im j/w
<img src=\'http://i49.photobucket.com/albums/f263/HBNR86/sigpicjpg.jpg\' border=\'0\' alt=\'user posted image\' />
<span style=\'font-size:8pt;line-height:100%\'>Mods: Eibach Springs, American Racing 17&quot; Coil Chrome Rims, Cooper Zeon Tires (235's), Front &amp; Rear STB's, Tinted Windows, Mesh Grill, Painted Interior, Custom Exhaust, Custom WAI, B&amp;M Shift kit, Innovatek DVD/MP3/CD/TV tuner, Innovatek 7&quot; LCD In-Dash Flip Out Screen, Cleared Headlights.<a href=\'http://www.cardomai
Rubered00 is offline   Reply With Quote
Old 04-11-2006, 09:14 PM   #19
I dont drive fast around corners. That's for kiddies that are trying to impress people on the streets with "cheater" burnouts. I level off and hit the gas.
