Old 10-03-2012, 12:29 PM   #1
SprtSedan01
SprtSedan01 is an unknown quantity at this point
Send a message via AIM to SprtSedan01
starts but shuts off
Ok, looking @ a 2000 Alero V6 auto. Just dropped in a newer engine w/80k miles on it. After the swap, it will start but immediately shuts off. Any ideas what could be the problem.?. Thanks in advance.
Will Warren
*USAF*
*00 Passat 1.8T*
*00 Alero 3.4*
*01 Alero 2.4*
*10 Expedition*
SprtSedan01 is offline   Reply With Quote
Old 10-03-2012, 12:40 PM   #2
mfuller
Is the dashboard security light on?
You may need to do a security re-learn.
Otherwise, check to see if you are getting gas.
Old 10-03-2012, 12:44 PM   #3
SprtSedan01
Yes it is, can that be done @ home or need to take to dealer?
Will Warren
*USAF*
*00 Passat 1.8T*
*00 Alero 3.4*
*01 Alero 2.4*
*10 Expedition*
Old 10-03-2012, 02:00 PM   #4
try leaving the key in the "on" postion for 10 mins, then start the car. cause of the security light.
Old 10-03-2012, 02:12 PM   #5
mfuller
After attempting to start the engine, if the "SECURITY" light flashes or stays on, wait ten minutes with the key in ON until the light goes off. Then turn the ignition to OFF before attempting to start the engine again.
