Old 03-06-2004, 04:49 AM   #1
alerocity
could someone explain enrichment to gas to me?
thanks
Old 03-06-2004, 07:51 AM   #2
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
this might help get an idea of it, even though I think it doesn't adequately describe it:
http://www.andial.com/content/930/fuel_enrich.htm
also, know that the fuel injectors spit the air-fuel mixture in at a certain ratio, usually about 50/50 by volume. But when the ratio is altered, performance is changed.
Lean (more air than gas): better mileage, hotter combustion
Rich (more gas than air): worse mileage, more horsepower/torque
And I'm sure somebody can elaborate for better details, definitions, etc.
I hope this helps.
Old 03-06-2004, 08:58 AM   #3
haulmarc
actually the fuel injectors only add fuel. also, the air/fuel ratio is closer to 12:1 on enrichment for power and 15:1 leaned out for best mileage.
Old 03-06-2004, 11:52 AM   #4
overdrive75
^^ what he said, 12:1 is generally enrichment mode, which is usually only entered above 90% TPS And its primary function is not performance, while there is a slight gain, it is to keep the catalyst from overheating. Oh and 14.6:1 is where these cars usually operater, pending, not in enrichment of in some mode due to altitude or temperature.
Old 04-16-2004, 12:48 AM   #5
Pacho
How much more horsepower can you expect from changing the air to rich?
