03-04-2012, 03:16 PM
head gasket
Is a thicker head gasket better?
03-04-2012, 03:27 PM
well it reduces compression so for a boosted build... yes it is...
03-04-2012, 06:19 PM
we'll find out, as i'm using a .074" thick one compared to my previous two .030" ones.
03-05-2012, 07:34 PM
Ion let me kno I want to keep the 10:1 compression when I build my engine. so I want a thick gasket to keep it safer.
03-05-2012, 08:53 PM
clearly you don't know how it works... by adding a thicker gasket it reduces the compression ratio... if you want to keep the 10:1 you have to keep the stock thickness... For your turbo build I suggest a thicker one that will reduce it to somewhere like 8,9 like Ion did.... to keep it safer you want to reduce compression ratio to avoid knock when boosted...
talking at your turbo build I'd like to see some pictures of it ?? I'm interested
03-08-2012, 10:43 PM
Look at my page on Facebook kswilliams1234@yahoo.com
03-08-2012, 11:01 PM
03-09-2012, 06:01 AM
That was my holset turbo setup damn thing was a big oil cooler. Had my block temp all over the place, turbo blow a seal within 2k after install. Nice spool but to damn hot. The straight up down pipe I had for one month riding with no hood. Intercool changed.when turbo blow caused runaway, bottom of intercooler full of oil. No bumper at all. Cover hanged on intercooler and has a cutout about two inches from the headlights. Intake gone 2.3 swap. As you can c I'm using 2 inch charge pipes need 2 upgrade
03-09-2012, 11:32 AM
z24 turbo? that's ghey.....
03-09-2012, 12:00 PM
Where did you find a place to get a thicker gasket. I looked on Cometic but they just showed a .051 for my 3.4L. I was going to just get a PermaTorque Severe Duty head gasket for my build.
2002 Grand Am GT Turbocharged
Garrett GT35 / Turbo Headers / 2.5" high flow DP / 60lb Injectors / Custom SLP Exhaust / Ported 3500 Heads / Ported 3500 UIM/LIM / 65mm TB / Turbonetics Evolution WG / Greddy Type-RS BOV / Casper Adjustable FPR / Casper High Speed Fan Switch / Speedbuilt F/R STB's / Next Level F/R Sway bars / Eibach Springs / Dual Gauge Pod with Aeroforce Gauges / Big Four Upgrade / HP Tuners and more!
"Living is doing everything you want to do and dying is everything else"
03-09-2012, 12:35 PM
you can order whatever size you want, just tell Cometic. they're all made-to-order
03-09-2012, 02:18 PM
Oh well that makes sense. What size would you recommend using for boost? This part is all new to me so I wouldn't know what size gasket I would need. Or would Cometic be able to help me out if I told them what I needed?
03-09-2012, 05:37 PM
they would not be able to tell you
stock size is fine. there's really no reason to go thin or thick unless you want to change compression slightly or that's the only size available.
03-09-2012, 07:23 PM
So will it be safe to get the one from Felpro or should I pony up and buy a Cometic?
03-09-2012, 08:01 PM
in my opinion
boost = MLS gasket
no boost = doesn't matter
03-09-2012, 10:14 PM
Yeah I was going to say use an MLS gasket.
I'm going to be using an MLS gasket on my 3400 build and I'm staying NA. Better safe than sorry in my book
04-16-2012, 08:01 PM
For those wondering what MLS means... Multi Layered Steel
04-16-2012, 08:05 PM
For those wondering, the .074" gasket is working perfectly. Car is better than it's ever been, even stock. Of course that's mainly attributed to other parts of the system being replaced and properly done, but yeah.
04-22-2012, 01:29 AM
Congrads. What track time are you going for now that its built?
04-23-2012, 02:04 AM
Low 12's high 11's
