12-07-2010, 11:12 AM
guage lights
i was wondering if there is a way to have the gauge lights come on when the car is on, instead of having them on with the parking of headlights, reason being is my tint is dark and some times i have to turn my lights on to see the gauges better,
any ideas welcome
thanks.
12-07-2010, 11:47 AM
i believe the word your looking for is gauge.
you can just turn your headlight knob to on and it will put your headlights on along with the interior lights which includes your gauges.
12-07-2010, 12:12 PM
fixed, i know i can turn my marker lights on and my dash lights come on, but i want it so i dont have to turn the markers or headlights and have the gauges still light up
12-07-2010, 06:08 PM
If you had a diagram for the main plug going into the gauges you could make a bypass switch with some wire and a switch ... You would just have to splice into a power wire that's hot with ignition on (would just need to make sure you fuse the wire if it's not already) , run that wire to one side of the switch and then after figuring out which wire on the main gauge plug splice it it and run that wire to the other side of the switch. Then you could just flick the switch and it will supply power to the gauge illumination.
Hope that make sense ... If not I'll try and draw a diagram of what I'm talking about.
12-07-2010, 07:05 PM
i was thinking of just finding the power wire for the gauge lights and running a jumper wire to a switched power source in the fusebox, only thing is i will lose the dimming feature, somthing i was trying to avoid
12-07-2010, 09:44 PM
Unless you already have an aftermarket radio you can jump off the windshield wiper fuse. Also, couldn't you just find the main power in for the dimmer and use it to wire all the lights to the ignition?
If you do this, can you do a write up? I actually kinda like this idea when combined with white leds. Kinda give it the look of a Toyota or Honda gauge cluster.
Hell, I might try and figure this out on my own, good idea.
I'm a minitrucker-every build is a budget build
12-08-2010, 10:52 AM
im going to do this today, and i will do a write up with pix.
oh where can i find a wiring diagram
12-08-2010, 12:57 PM
We have them onsite... but your gonna have to search for them. (I uploaded them from Haynes... but forgot where the link was on here)
12-08-2010, 03:21 PM
did the write up on a new thread
12-08-2010, 04:15 PM
08-04-2011, 06:23 AM
how dark is your tint ?
