Old 12-12-2010, 02:13 PM   #1
Hectic
Hectic is on a distinguished road
Rear view mirror rattling
So when my subs hit, my mirror vibrates as would any other mirror, but also makes an annoying vibration sound. When I grab the mirror, it stops of course.
In Ontario, you must have a rearview. So removing it is out of the question.
What have some of you guys done?
1999 GX LD9 Sedan -- RIP 'ho
Hello 2012 Sonic LT
Hectic is offline   Reply With Quote
Old 12-12-2010, 03:16 PM   #2
02AleroEco
02AleroEco is on a distinguished road
Send a message via AIM to 02AleroEco
I had the same issue when i first got my system..
Take an allen wrench** ( cant remember size) and just tighten the mirror down, thats what i did and it solved the issue
02AleroEco is offline   Reply With Quote
Old 12-12-2010, 04:41 PM   #3
Lucalare
It's a torx (star) screw, not allen.
1987 Honda Rebel 450
Old 12-12-2010, 05:32 PM   #4
Hectic
Just tried the 7/64, worked.
I know if you turn too hard with an Allen wrench and strip the screw, your effed.
Hello 2012 Sonic LT
Old 12-12-2010, 05:49 PM   #5
Tuse31
Tuse31's Avatar
Tuse31 is on a distinguished road
I had the exact same problem. What I did was, I went out out Wal-mart and got some 3M mounting tape. (It's got a 5lb. hold weight and it is a bit spongy and stretchy.) Then I took the mirror off and put the tape all around the black metal housing that touches the windshield when the mirror is secured onto the windshield. It helped a little bit. I also took apart the reading lamp housing and put some in there to secure the copper holds for the bulbs which also were rattling. This also helped. Good luck!
Tuse31 is offline   Reply With Quote
Old 12-12-2010, 06:44 PM   #6
Afugy
I poop alot
Afugy's Avatar
Afugy is on a distinguished road
Use the search. Its a good thing to know that most plastics start to fail at 160 F to 200 F, and if its cold its likely to crack, but room temp should work fine. Try getting VHB tape if you can, it has a stronger hold and a way longer life. Seeing how I fixed the rattle on the out side of the trunk 6 years ago and its shows no sign of wear.
Originally Posted by Afugy View Post
I found that you can use the 3M VHB tape on the rearview mirror too.
I should have taken picture when I did it to show you how its done. On a hot day I used 2 smallest allen wrenches to hold open a gap at the top of the mirror, cut a piece of the tape down to about 1/8" x 3/4" and used a 3rd small allen wrench to get the tape into the gap. Just don't try and pry with the allens they are there just to hold open the gap, use your fingers to open up the gap, the glass in the mirror is thick but you still don't to risk chipping the glass.
I'll take some pictures of how it came out later.
Afugy is offline   Reply With Quote
