02-20-2009, 04:03 PM
Where to get power
Hi, I was wondering where to get power for LEDs Inside the car (doors, dash, ect..) and relay it all to a switch.
Also wondering where to get power if i want to put LEDs in the front lights?
Thanx
Take Life's Curves Sideways, and Drift!
02-20-2009, 04:29 PM
front lights, put them on a switch w/ constant power.
for interiors, patch a line into the fuse that into the very top right of the passanger fuse box. it'll turn on when your DRLs kick off and headlights kick on.
you can connect to constant power, but you won't see them during the day anyway.
other then that, run ONE fused line into the center console, then go to radioshack and get a set of barrier strips + jumpers.
http://www.radioshack.com/product/in...ductId=2103229
and
http://www.radioshack.com/product/in...ductId=2103227
you can easily turn that one wire into several easy to run, connections.
happy wiring
02-20-2009, 04:37 PM
wouldnt just patching into the headlight fuse be sufficient?
02-20-2009, 05:03 PM
nah. if it blows you have no headlights. my way, if the fuse blows, you just lose your interior accessory lights...
02-20-2009, 05:29 PM
Off Topic: Wow another Qc member YEAH!!!
02-20-2009, 05:38 PM
OT... your slow.. hes been around for a little while now...
02-20-2009, 05:40 PM
yeah i see.. do you have a scematic for the fuse box?
02-20-2009, 05:42 PM
i do not. someone must
02-23-2009, 10:33 PM
YEAH !!! Quebec baby!!
lol Thankx for the info!!!
The LED in the headlights, Is there a possibility that condensation forms inside the light cavity?(bad seal)
02-23-2009, 10:39 PM
yes there is a possibility.
02-24-2009, 11:37 AM
crapper, and where do you drill to insert the LED?
05-03-2009, 03:12 AM
Kinda off topic, not meaning to bash, but what is the point of putting leds in the headlights? I understand using them as a light while you're driving but random colors in your headlight doesn't seem intriguing to me.
-Gavin
05-03-2009, 04:59 AM
The Drunk
He's talking about putting like 2-3 leds per side, so when your car is parked your headlights glow. Unless he's going all out and doing something crazy. It looks pretty cool IMO. Basically during the day you can't see them at all, and your headlights drown them out completly so no worrys there. Also the battery drain is so minimal on say 8 leds it's not worth even thinking about unless you don't start your car for over a week (probably a lot longer but I know someone has a shot battery and would cry) There's a not so good pic of it here a couple posts down...
http://www.aleromod.com/forums/showt...=led+headlight
`03 Alero GL 2.2L Ecotec
05-05-2009, 11:09 AM
Yup thats what i m lookin into!! its kinda like backlighting...
05-05-2009, 03:28 PM
don't drill into the lights. you can mount them in, next to your headlight bulbs, just be sure the led points back toward the reflector.
05-06-2009, 06:36 PM
???? sry you lost me??? lol
05-06-2009, 08:07 PM
Ooo ic, now that I know what you guys are talking about I want to do it, haha.
05-06-2009, 11:23 PM
oh yeah ! but since its illigal you need a switch on the LEDs
05-06-2009, 11:38 PM
The Aleromod PITA
i was wondering if it was legal for you, since your there
