10-13-2008, 10:04 PM
Defeat < Giving Up
AC/heater problem
So my vent selector doesn't work anymore. I did a search and found one topic but it was never answered. My AC/heater works but all vents are blowing at once and I cant just defrost windshield or windows, or just blow in your face or at your feet if you get what I'm saying. I've checked and it is plugged up right.
This is the knob that doesnt work.
WhiteLiquid
10-13-2008, 10:06 PM
Its Beer Thirty
I would pull the radio bezel off and see if the vacuum lines are hooked up still or if one is broken or cracked.
edit: You checked the vacuum hoses that go to the back of it?
10-13-2008, 10:09 PM
Defeat < Giving Up
Yea...and that one in particular breaks down and has springs inside of the Connection. I checked them all and they are in place perfectly.
WhiteLiquid
10-13-2008, 10:12 PM
you checked they were in place, but do they hold vaccuum?
10-13-2008, 10:17 PM
Defeat < Giving Up
You mean like a Finger check?
WhiteLiquid
10-13-2008, 10:21 PM
Its Beer Thirty
When you pull the hoses off you should be able to hear it pulling air in.
i don't have a wiring diagram, but maybe there is a broken wire from that harness or 2 r shorted toether? now that i read it again rear defrost not working would be electrical, not vaccuum. but its still wierd that all vents blow at once...
10-13-2008, 10:22 PM
you might not hear the vaccuum if, but yea finger check you should be able to tell if there is vaccuum there.
10-14-2008, 12:43 AM
On mine the actual knob broke (cracked). There was hardly any resistance.
10-14-2008, 09:21 AM
Defeat < Giving Up
my knob still works fine....and the rear defrost does work (its not ascociated with the knob though, its a seperate button)
I'll check the vacuum today
WhiteLiquid
10-14-2008, 10:58 AM
oops sorry i saw u couldn't defrost the windows and just thought u meant rear window for some reason
10-14-2008, 02:18 PM
Defeat < Giving Up
ok just checked and I dont hear or feel any vacuum....
Now what?
WhiteLiquid
10-16-2008, 05:38 PM
Defeat < Giving Up
bump* for no vacuum pressure
WhiteLiquid
10-17-2008, 02:14 AM
The purple hose is the vacuum supply. You should have vaccum available any time the engine is running. There is a vacuum reservoir under the dash as well. Also check the vacuum connections on the intake manifold.
