Old 08-01-2009, 11:02 AM   #1
AtomicX
AtomicX's Avatar
Center bore on rims
Hey I just bought the set of rims and tires of Sburke, and for some reason the center bore on the rim is smaller then the one on my hub. I don't get why? I just checked the website he got them from, http://www.wheelsnext.com/wheels-rim...yperblack.html, and it says it fits the alero.
I went to every tire place around here and they all said they will not bore it.
HUH??
Old 08-01-2009, 11:23 AM   #2
KenshinZero
KenshinZero's Avatar
KenshinZero is an unknown quantity at this point
Did they give a reason why they wouldnt bor it? that seems kinda odd to me, maybe it has to do with the strength of the rim? IDK.
1999, RED Alero GX
KenshinZero is offline   Reply With Quote
Old 08-01-2009, 11:24 AM   #3
they probably just don't have the proper machine to do it. I know in denver there are only like two places that will do it.......
Old 08-01-2009, 11:34 AM   #4
AtomicX
AtomicX's Avatar
Any reason why they arn't fitting in the first place? I mean it says right on the site it fits the alero.
Pics here..
Old 08-01-2009, 01:33 PM   #5
Even from the pics it looks like it should be good..
Do they not fit on the back either?
Old 08-01-2009, 01:40 PM   #6
AtomicX
AtomicX's Avatar
Nope, backs the same thing, its about 2mm to short
Old 08-01-2009, 01:57 PM   #7
That's crazy. The center bore needs to be 70.3mm (just a touch over 2.75").
Old 08-01-2009, 02:04 PM   #8
AtomicX
AtomicX's Avatar
Yup, I measured 2.5''
Old 08-01-2009, 02:08 PM   #9
are you sure it's not rust on your wheel hubs? have you tryed getting them to go on by torqueing the wheel lugs?
Old 08-01-2009, 02:15 PM   #10
AtomicX
AtomicX's Avatar
Yup, but there is no way that the center hub will go inside the rim, its almost the same exact size, the center of the rim needs to be a little bigger.
Old 08-01-2009, 02:27 PM   #11
the easiest method (especially since those have like a 45mm offset) would be just to get a spacer.
Just get an accurate measurement of the center bore. It may even be stamped on the inside of the wheel somewhere. Or just give them a call...
Old 08-01-2009, 02:32 PM   #12
AtomicX
AtomicX's Avatar
This is what I got when I measured the bore of the new rims
Old 08-01-2009, 02:40 PM   #13
Yeah, definitely too small, but for spacers you'd want the exact size to the tenth of a millimeter. Is there any numbering or anything on the inside of the wheel?
Old 08-01-2009, 02:42 PM   #14
AtomicX
AtomicX's Avatar
Nope, but it came with 4 plastic rings, those won't help right?
Old 08-01-2009, 02:44 PM   #15
Well, you could measure the outside with a caliper for the size. Most likely those were for whatever car the wheels were originally bought for.
Old 08-01-2009, 02:44 PM   #16
AtomicX
AtomicX's Avatar
They were originally bought for an alero lol.
Old 08-01-2009, 02:46 PM   #17
Well, then somebody messed up somewhere... They may have thought it had the smaller bore size like the Achieva had (57.1mm)
Old 08-01-2009, 02:49 PM   #18
AtomicX
AtomicX's Avatar
Yeah this doesn't make sense, on the recipet it says it sent Centering rings that are 73.1OD 70.3ID WN
Old 08-01-2009, 03:01 PM   #19
Do the rings fit over the center bore?
Old 08-01-2009, 03:03 PM   #20
AtomicX
AtomicX's Avatar
nope they dont
