Originally posted by jamcllw@Aug 25 2005, 06:41 PM
you can here the fuel pump. Turn the key to the on position and if your pump is working you'll here a humming sound coming from the tank for about 5 seconds. Pfyc has a good how-to for changing the fuel filter.
that shat don't work. When my fuel pump was weak. it still made the noise, but when ya crank it over no fuel was coming out of the fuel rail.
TO CHECK FOR FUEL on the 3.4L. - goto the shradder valve on the fuel fuel next to the power steering pump. Undo the cap, then take a philip screwdriver and push on the valve. then have someone turn over the car.. you should have fuel coming out, if not your fuel pump is goner.
cost dealer price for a fuel pump is like 240 bucks. so retail is like 300.
