04-06-2009, 08:35 AM
Major Misfire
Put the car all back together, and now, misfire!
misfire so bad the car wont stay running, REALLY old fuel in the tank, 2+ years old...
any ideas?
04-06-2009, 08:37 AM
lol sick, it could be the water in your gas or you could have your wires mismatched
04-06-2009, 08:42 AM
hmm, ima check wires, can someone give me the order on the coil pack and then order on the engine?
i thought the order for the engine was
1 3 5
2 4 6
and the coil pack had the numbers right on it
ima add like, 5 gallons of fuel to the car and put some water remover and fuel injector cleaner into the tank, and maybe i fits out there, fuel revitalizer?
04-06-2009, 10:55 AM
Wide Open Throttle
Disconnect the fuel line from the rail and run the pump to get the gas out. Then change your fuel filterand put new gas in. I wouldn't be surprised if the injectors are gummed up inside as well from sitting. Letting a car sit for 3 years = all bad.
04-06-2009, 12:42 PM
fuel injector cleaner?
water wetter?
Edit: nate already suggested these himself... imma idiot
04-06-2009, 12:54 PM
your coil pack should be 5-2-3-6-4-1
Sometimes the numbers are mislabled on the coils, cuz they also fit other cars like the Grand prix..etc.
04-06-2009, 12:55 PM
thanks! it is wrong so that is my problem! thanks!
04-06-2009, 02:11 PM
Wide Open Throttle
1 and 4 can be switched, 6 and 3 can be switched, and 2 and 5 can be switched. Both fire at the same time
04-07-2009, 03:56 AM
is there a diagram of this?
AUTOBOT
04-07-2009, 07:29 AM
There is a diagram of sorts in the Haynes manual.
04-07-2009, 08:30 AM
yeah, i got home, the wires are correct, now im beginning to think its a vacuum leak,
newest thing, when i start my alero, it goes right to redline, without me even touching the pedal, do the V6's TB's have gaskets? i think there is also a loose bolt on the TB....
04-07-2009, 12:32 PM
Either way you need to get all that old gas out of the tank. It is not stable for that long. I had to dispose of 18 gallons of gas in my boat because it sat for a couple years.
