Old 08-25-2011, 10:42 PM   #1
TdotAlero
TdotAlero's Avatar
TdotAlero is on a distinguished road
Unusual transmission behaviour
I searched the forums and Google and didn't come up with any clear solution.
Here's the story. Car is 3.4 auto.
About a week ago I unplugged my battery for about 15 minutes to unwire and remove the sub from the trunk. Right after reconnecting the battery I loaded my Alero with a bunch of furniture and had to drive around 10kms up and downhill. I pretty much drove like an a$$ due to heavy load.
Since then the transmission has been acting odd. I do city driving in heavy traffic every day for about 15kms each way. Now everytime I take off from green light, the transmission is "lagging" in the first gear. Like as if it was struggling to power the car. I keep my rpms below 2500. It only does the lag when I go from a complete stop, and only in the first gear. Also it tends to downshift when going uphill much earlier than it used to before. No jerky shifting between the gears though.
My question is, should I unhook the battery and then drive it more aggressive to let the car "relearn" the driving habits.
Or is it a sign of my tranny starting to give up.
Edit: 260,000km on the transmission
2000 Oldsmobile Alero GL 3.4 V6 284.000km FOR SALE!!!
2008 Ford Escape Limited 3.0 V6 130.000km
Follow the Southwest Ontario Meet thread!
TdotAlero is offline   Reply With Quote
Old 08-25-2011, 11:06 PM   #2
zearchyo
zearchyo's Avatar
zearchyo is on a distinguished road
have u checked fluids on it?
zearchyo is offline   Reply With Quote
Old 08-26-2011, 12:04 AM   #3
TdotAlero
TdotAlero's Avatar
No, not in a while.
I was planning to change the transmission filter and flush the fluid, but the neighbour mechanic told me that at this point it might cause more bad than good.
Old 08-26-2011, 12:11 AM   #4
Mine is a 2.2 so a it different but I have had go through strange moods like that as well. Most of the time I noticed it after steping on it and spinning of really wierd. Then It will be really laggy for a bit then go back to usual. But for your next changes put in some the Lucas oil stuff. I highly recamend it. It was shoring really hard a while back and that fixed the problem.
Old 08-26-2011, 01:19 AM   #5
alero_bmxer
alero_bmxer's Avatar
same problem i had. cant remember what the part name was exactly but i think it was a solenoid in the trans that went bad. PITA by the way to fix
Old 08-26-2011, 10:51 AM   #6
zzyzzx
zzyzzx's Avatar
I would check the fluids first. 161,556 miles is about when I did my first transmission fluid and filter change on my 1995 Escort, and it currently has 203,500 miles (327,501KM to you) and it still has the original automatic transmission and it works just fine.
I can't imagine that the furniture load was that bad. It's not like you loaded up your car with bricks or bags of cement (did that once to the Escort, and I think I broke the already very rusty rear springs that way)
Old 08-26-2011, 11:14 AM   #7
zzyzzx
zzyzzx's Avatar
I mean, you weren't doing this, were you:
Old 08-26-2011, 03:39 PM   #8
zearchyo
zearchyo's Avatar
damn this people need to buy a damn truck not use the accord as one
Old 08-26-2011, 03:46 PM   #9
Goodman
Goodman's Avatar
Goodman is on a distinguished road
WTF? that is so stupid!!!
Risking to break something on the car or the fridge & a possibly big ticket if a police car saw that on the road & all that for what... saving $30-50 for delivery
Goodman is offline   Reply With Quote
Old 08-26-2011, 04:26 PM   #10
I'm calling BS on that pic just due to the fact the rear of that car isn't on the ground.
This has happened to my Alero as well. However it cleared up on it's own.
Old 08-26-2011, 06:27 PM   #11
Fuzzyspudkiss
Fuzzyspudkiss's Avatar
Fuzzyspudkiss is on a distinguished road
Thats what I was going to say, Unless that Accord has leaf springs, I would imagine the wells would almost be to the tire...I loaded like 400 lbs of bagged dirt in the trunk of my Alero and it was ridin low lol (it was only for like 2 mi)
Fuzzyspudkiss is offline   Reply With Quote
Old 08-26-2011, 06:39 PM   #12
SIUlero
SIUlero's Avatar
SIUlero is on a distinguished road
Really, an empty fridge isn't all that heavy...just bulky. I'd guess around 100-130 lbs. Wouldn't drop the rear a whole lot...noticeable, but not dragging the ground.
SIUlero
'01 Alero GL
'72 Cutlass Supreme
http://www.cardomain.com/id/CrazyOldsGuy
SIUlero is offline   Reply With Quote
Old 08-27-2011, 12:20 AM   #13
TdotAlero
TdotAlero's Avatar
Driving back from work today, same problem. Not so obvious though. Drove on the highway, steady rpm at 110 km/h. About 80 km of highway driving later the car drives like brand new in the city traffic. Could it be that the transmission oil just needs to get a good 'work out' on a highway once in a while? Anyway fluid check will be done tomorrow.
If that doesn't fix it then I will just live with it. I guess it's another "GM thing".
Old 08-27-2011, 07:39 AM   #14
Rippasnortus
Rippasnortus is on a distinguished road
An empty fridge is not heavy, I've carried them on my back for short distances but in the cardboard so you have something to grab on to. That was when I worked on the loading dock. I did see this car on the news one day last week and not sure where it was as I only caught the last of the story.
Rippasnortus is offline   Reply With Quote
Old 09-24-2011, 01:50 PM   #15
nicothehut
nicothehut's Avatar
nicothehut is on a distinguished road
The picture is REAL. Taken in Vancouver about month ago it even made the 6 pm news that night. The store clerk call the cops before the man could drive away. If you note he even tried to use the seatbelt as rope.
Bessie Braddock: “Sir, you are drunk.”
Churchill: “Madam, you are ugly. In the morning, I shall be sober.”
nicothehut is offline   Reply With Quote
Old 09-25-2011, 07:14 PM   #16
Black_Mamba
Black_Mamba's Avatar
Black_Mamba is on a distinguished road
Send a message via AIM to Black_Mamba
Check your Cat Converter and o2 sensors too if its still happening. Something very simillar happened to me like that and I was so paranoid that it was the transmission and I was screwed in having to buy a new one, instead it was just a clogged catalytic converter
2001 GLS 3.4L Coupe "Black Mamba"
Mods: K&N Cold Air Intake, 8000k H.I.D. Low Beam, 3000k H.I.D. Fog Lights.
Wants: SLP Exhaust, Ported UIM & LIM, 65mm TB, Lowering Springs, Rims, Black Interior.
Black_Mamba is offline   Reply With Quote
Old 09-25-2011, 07:43 PM   #17
Ya, one time I accidentally left the intake sensor unplugged and it writes really funny, I plugged it in, cleared the code and it was fine again.
