Don't know if you got it installed or not, but the only wire I couldn't find on the writeups was the tach wire; its in the engine compartment behind the coil packs, its a little white wire in a harness. I spliced into that one and everything works fine. Oh, first time I hooked everything up, I had the wrong accessory wire and the a/c wouldn't come on. There are two in there the same color and only one is the correct accessory for a/c. I didn't solder anything until I tested all the connections. Good luck, if you're not done already...
