04-02-2009, 08:09 AM
shifter area
Hi all
Does someone have a how-to to take the part between the front seats apart? If possible a video? I have a 2 dr automatique, if that makes a differents.
I want to install LEDS in there and when i went to the store, there are SO many types of LEDs, which ones should I take?
Thanx!
Take Life's Curves Sideways, and Drift!
04-02-2009, 08:47 AM
Ok, remove the little clip that holds the shifter knob on (on the front side of the shifter knob). Then lightly pry up on the bezel around the shifter, the part that has your front cupholder in it) and it should pop up. Then disconnect the wire to the ETC switch. Now, open the console up and take the rubber mat out of the bottom. There are some screws in there. Then slide your seats all the way back and there is a bolt on each side holding it on. Then up near the front is a screw on each side (you have to pop the little oval shaped covers off). I think that's it.
04-02-2009, 10:00 AM
You got beat by an Alero!
I think I have done this about a hundred times when I was trying to fix my e-brake
04-02-2009, 11:14 AM
took it out to put my stereo in.
04-02-2009, 01:02 PM
I wanna pur LEDs une cup holder, but didnt know how to open it up to pass wires :P
Now i need to find which LED would fit there...
04-02-2009, 01:04 PM
There is a cup holder how to....
04-02-2009, 01:05 PM
Theres cup holders?
04-02-2009, 03:54 PM
Originally Posted by StoopidAlero
Theres cup holders?
the one closest to the stereo shouldnt count, its worthless...lol
04-02-2009, 03:57 PM
Let's Play Army!
^ it's technically the ashtray holder.
Originally Posted by black
04-03-2009, 10:29 AM
The Aleromod PITA
the one closes to the stero is ok once you change your shifter knob to something else, btw anyone know where to find a cheap but decent shift knob, i look to autozone but nothing suited my fancy
04-03-2009, 10:39 AM
theres no such thing as cheap and good.
i too, have never seen a shift knob i like (other then the solstice shift lever)
04-03-2009, 10:53 AM
I have a Bonneville shift knob. Mostly just because it's a little different. It's really nothing special.
04-03-2009, 08:18 PM
but in the how to, which LED should i buy????
04-03-2009, 08:29 PM
depends. you can get a direct replacement (not sure what size bulb it is) or like what i did, and just drill holes in the white plastic underneath.. then mount 7x5mm leds underneath the PRND321 spots.
04-03-2009, 10:30 PM
The Aleromod PITA
i got the 194 replace ment in the PRND321, easy just twist it, it comes right out
04-04-2009, 07:36 AM
Sweet... what about the one for the cup holder( where your water bottle is) What LED did you put there ? a 2Volt+resistor?
04-04-2009, 07:50 AM
mine? that definitely has a how to for it. mine is a little trickier then just that.
half way down page 1:
http://www.aleromod.com/forums/showt...&highlight=led
i used 3mm (cuz i had them) you can use 5mm. i used those before the 3mm.. and it worked just fine.
04-04-2009, 08:17 AM
You didnt put any resistors on the LEDs?
04-04-2009, 08:20 AM
i put them on the wires, down further. it makes life easier, in this case.
as long as you have a resistor in the line... ANYWHERE... it works. it doesn't need to be attached directly TO the led.
04-04-2009, 07:25 PM
The Aleromod PITA
i wish i knew more aobut resistors and stuff, then id have my car apart doing all that
