Heres a little info for the guys who play with leds.
http://physics.bu.edu/py106/notes/Circuits.html
http://www.1728.com/resistrs.htm
As your led setups expand, you may run into the need to have a high wattage resistor, but with the standard supply for resistance.
Your average resistor is 1/4W or 1/2W. An average led runs 0.072W @ 3.6V. If you wanted to run more leds in parallel off one resistor, you would need a higher wattage resistor
After fiddling with Ohm's law a little... I came to this answer.
Problem: You need X Ohms @ Y Wattage
Explanation: Wiring resistors in parallel will cause the resistance to be 1/R (x being your resistance) [use the calculator above]
So? for every pair you have in parallel , put a pair in parallel behind it, and you'll stay at the same resistance.
Matching the number in series, with how many resistors you have in parallel, and you'll always end up at the same resistance.
Examples:
using 470ohm 0.5W resistors
1/470+1/470 = 235ohm @ 1W
...combined with another in series...
235Ohm + 235Ohm = 470Ohm @ 1W
1/470+1/470+1/470 = 156.67ohm @ 1.5W
...combined with 2 more in series....
156.67Ohm+156.67Ohm+156.67Ohm = 470ohm @ 1.5W
