Old 08-13-2013, 04:45 PM   #1
03gxeco
03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute
cooling system flush?
I have a bottle of flush and new coolant ready to go in after my water pump install but as all of you know, the radiator is kinda up under shit. SO how the hell am i supposed to flush my cooling system?
2003 V6 gl coupe. Mods: cold air intake, Resonator Delete, GAGT muffler, GAGT torqued 5 spoke rims, grand am pre02mirrors ,cross drilled and slotted rotors by powerstop, 1999 hvac blue knobs
03gxeco is offline   Reply With Quote
Old 08-13-2013, 04:49 PM   #2
There is a block plug somewhere. Or you can pull a bottom radiator hose amd let it all dump that way.
Old 08-13-2013, 04:50 PM   #3
03gxeco
that is how i drained it when i put the pump in. i just didn't know if there was an easier way. luckily the only thing in the cooling system right now is some water.
Old 08-13-2013, 05:49 PM   #4
Unless your drain plug in the rad cant come out, its bottom radiator hose, or the block plug which idk where that is.
Ive drained my coolant from the radiator hose before because i didnt know where the plug was.
Old 08-13-2013, 07:18 PM   #5
03gxeco
ha found the drain plug. she only took like 6 quarts of coolant though. not even. plus i think my LIMGs are bad. but my car passed inspection today so im happy with her.
Old 08-13-2013, 08:28 PM   #6
Yeah if you drained the radiator, there is still coolant in the block.
