Old 07-26-2008, 11:23 AM   #1
Bmorezcmunee
Bmorezcmunee's Avatar
Bmorezcmunee is on a distinguished road
fog light issue?
my fog lights havent worked since i bought the car. when i hit the switch i hear the click of the fuse (or flasher, whatever that big fuse is, sorry the proper name escapes me) on the passenger side. but my fog lights still dont work. where else should i begin looking for problems? fyi = i havent checked the bulbs yet. any other place i should check before the obvious?
Bmorezcmunee is offline   Reply With Quote
Old 07-26-2008, 12:57 PM   #2
CactusWill
You mean the relay. Check the bulbs first of course, but it sounds like its the relay.
Old 07-26-2008, 02:06 PM   #3
Bmorezcmunee
thanks Will. ill definitely look at that
Old 07-26-2008, 09:38 PM   #4
red99ws6
red99ws6 is on a distinguished road
where would the relay be and how do u check it. mine are the same way havent worked since i got the car. i checked the fuse and bulbs.
red99ws6 is offline   Reply With Quote
Old 07-26-2008, 10:16 PM   #5
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
the relay is either under the hood or in the doorjam in the dash. (I forget for this particular relay) but the covers have a diagram showing what relays control which parts. Not sure how to check if its good though. also, once you have it checked out, if it still isn't working, check the wires for excessive corrosion, as they are quite exposed to the elements.
Old 07-26-2008, 11:24 PM   #6
check bulbs first, then the realy. just swap out the relay with one the same that u know works and see if they start working. then obviously u need to get a new one if it is bad or do without the thing u stile the relay from
