Old 08-13-2005, 12:30 AM   #1
-Alero-
-Alero-'s Avatar
ive noticed over time every now and then at certain steady rpm's the car sort of bumps, like it skips a beat but just barely enoughto tell. you know a missfire.
and i got my car scanned, and it said i had a missfire on cylinder 1.
so i take out the spark plu, clean it up an it looks perfectly fine.
and this spark plug alogn with the rest are fairly new, like 12k miles new. they are iridium something's.....
but anyways, what could be causeing this? is it the spark plug wires? mine are still stock wires.
could it be the radio!?
:feedback:
AUTOBOT
Old 08-13-2005, 01:54 AM   #2
slowandlow
slowandlow's Avatar
same problem i had a loose boot so when the car warmed up cilinder 1 wouldent work
Old 08-13-2005, 02:46 AM   #3
-Alero-
-Alero-'s Avatar
hmm i'll look into it, but do you think that the stock wires just arent cuttin it anymore?
AUTOBOT
Old 08-13-2005, 08:11 AM   #4
Could just be the plugs, like what happened to me
Old 08-13-2005, 05:09 PM   #5
sound_xtreme
sound_xtreme's Avatar
ya my plugs were bad around 80-90k. gaps were nasty. could fit the whole gauge in with room to spare
Cardomain
Old 08-14-2005, 12:12 AM   #6
-Alero-
-Alero-'s Avatar
well like i said, my plugs only have like 12k o nthem, but it also could be my cat....not sure if its clogged.
AUTOBOT
Old 08-14-2005, 05:12 AM   #7
-Alero-
-Alero-'s Avatar
well if it all comes down to it and it is the plugs. what do you guys recomend? and money doesnt matter hear, i will take the best of the best.
AUTOBOT
Old 08-14-2005, 06:50 AM   #8
sound_xtreme
ac delco. just take out the plug for cyl 1 and check it
Cardomain
Old 08-14-2005, 10:36 PM   #9
-Alero-
-Alero-'s Avatar
as i said, i already have, and i cleaned it up, and sprayed WD-40 on it and everything.......and i got the car scanned again and there is no missfire it says....(sigh)
AUTOBOT
Old 08-14-2005, 10:59 PM   #10
sound_xtreme
did you check the gap? and the iridium's arent supposed to be that good really. You can try getting new wires, i'd just get stock replacements though, as delco or whatever they are.
Cardomain
Old 08-14-2005, 11:21 PM   #11
-Alero-
-Alero-'s Avatar
havent checked the gap, they were the right gap when i bought them......but dont AC delco's spark less than iridiums?
AUTOBOT
Old 08-15-2005, 01:47 AM   #12
sound_xtreme
not that i know of maybe. i always thought iridiums were just meant to last longer.
Cardomain
Old 08-15-2005, 07:33 PM   #13
mikegett
mikegett's Avatar
Do you have the 3.4 v6? If so, was the car bought new? The 3.4's have a bad problem with missfiring for some reason. I bought my 03 brand new and it did it right off the lot. I took it in on several occassions and they all told me that it was a issue of the motor. I didn't believe it until I tested out three other cars with the 3.4. Every one did it. Had I of tested the car a bit more, I would probably never of bought the thing. Normaly the missfire is very slight. Just a light sputter in idle. However, I have had two occassions that the car died while using the AC on a hot day. My personal opinion is a altenator problem under heavy load.
Old 08-19-2005, 05:33 AM   #14
-Alero-
-Alero-'s Avatar
k i picked up some AC-Delco IRidium's. they were 5.99 each and for some reason i noticed it says "JAPAN NGK" on them.
so.....should i put em in or take em back?
AUTOBOT
Old 08-19-2005, 06:43 AM   #15
AftermathAlero
AC delco don't make iridiums. NGK from japan makes those. AC delco only make AC Delco plugs regular line, AC delco plat, and AC delco rapidfires.
so the plugs you bought are NGK's not AC Delco brand.
Old 08-20-2005, 01:21 AM   #16
-Alero-
-Alero-'s Avatar
Originally posted by AftermathAlero+Aug 19 2005, 05:43 AM--><div class='quotetop'>QUOTE(AftermathAlero @ Aug 19 2005, 05:43 AM)</div><div class='quotemain'><!--QuoteBegin--Alero-@Aug 19 2005, 08:33 AM
[/b][/quote]
lol i swear to go it says AC delco on the white party and then under it it says NGK iridium. maybe they are new? i'll get a picture.
AUTOBOT
Old 08-20-2005, 02:19 AM   #17
-Alero-
-Alero-'s Avatar
k here we go, this has to be the absolute worst camera i have ever held.....
AUTOBOT
Old 08-20-2005, 02:21 AM   #18
-Alero-
-Alero-'s Avatar
AUTOBOT
Old 08-20-2005, 04:05 AM   #19
AftermathAlero
Those are still NGK plugs. cept AC delco put they name on it to sell them as their own. Looks like the AC delco NGK market is cheaper then buying the NGK box.. hehehe 5.99 for ac delco's plugs labeled by NGK. or 12.99 each for NGK labeled plugs themselves.
When i looked online everywhere at autozone.com and even ac delco.com it only mentions these two as their own product
AC-DELCO_RAPIDFIRE 14 $4.69
AC-DELCO PLATINUM 41-940 $7.99
So ur plugs even though it says AC delco, There really still NGK's. What the model number for those plugs?
As long as those are gappged at .060 . They should be fine to use.
Old 08-21-2005, 02:04 AM   #20
-Alero-
-Alero-'s Avatar
k here they are
ACDELCO professional iridium plug
part number : 41-101
AUTOBOT
