Old 08-26-2005, 08:00 PM   #1
DRA-GON
DRA-GON's Avatar
DRA-GON is an unknown quantity at this point
Ok so I did my front brakes and rotors last week myself , I am going to try and do my back brakes on Sunday but was told that back calipers have some weird nut or something that you need a spacial tool to get them off , is this true with our cars or are they the same as doing the front ones?? :wtf:
<img src=\'http://i11.photobucket.com/albums/a175/looper90/SIG.jpg\' border=\'0\' alt=\'user posted image\' />
DRA-GON is offline   Reply With Quote
Old 08-26-2005, 08:45 PM   #2
SlickSketcher
SlickSketcher is an unknown quantity at this point
Send a message via AIM to SlickSketcher Send a message via MSN to SlickSketcher
my 99 was exaly he same front to back. i haven't checked my new 04 yet though.
2004 GL2 3.4L V6
SlickSketcher is offline   Reply With Quote
Old 08-27-2005, 01:27 AM   #3
bigd6983
the only difference is the e-brake, theres a pad that slips inside the rotor, if you go look at it you can tell that the diameter on the rear part where it sits on the hub is bigger than the fronts......just make sure its in good condition and you get it centered when you go to slide the rotor on.........
Old 08-27-2005, 09:54 PM   #4
SlickSketcher
yeah, the parking brake doesn't use the regular pads. they have their own pads on the inside of the hub of the rear rotor. it is definitely a noticable difference in size.
2004 GL2 3.4L V6
Old 08-31-2005, 03:26 PM   #5
alerochick242
I have an 02 and it took a grand total of 10 minutes to do both rear wheels. VERY easy to do and no special tool required!
Old 09-02-2005, 08:31 PM   #6
bigd6983
are all you guys changing out the anti-rattle spring(front only) and the clips that hold on the pads??
Old 09-04-2005, 01:33 AM   #7
slowandlow
slowandlow's Avatar
i am putting akebono pads and power sloted rotors on front and back
