Old 09-02-2011, 05:33 PM   #1
bentiac
bentiac's Avatar
bentiac is on a distinguished road
High idle / a bit rough
My engine started idling higher and higher and now it idles at 1k when warm (1200 when halfway warm)... the idle was a bit rough so I cleaned my maf sensor and recharged my cone filter... it's a little smoother now but the RPM is still high.
Checked the brake vacuum hose and no leaks there. No error codes or engine lights.
Should I try de-carbonizing (seafoam)? Anything else I need to check?
GS - 01 Alero Coupe - MT, CG-lock,Front/rear strut tower brace,WAI,Fidanza Short throw Shifter and custom short throw clutch, AGX adjustable struts and mounts, Dropzone Springs, speedbuilt front sway bar, Toyo R888.
CS - 06 RX8 - Special Edition Shinka, 285 Hoosier A6.
bentiac is offline   Reply With Quote
Old 09-02-2011, 06:24 PM   #2
Caboose73
Caboose73's Avatar
Caboose73 is on a distinguished road
Send a message via AIM to Caboose73
Check all the vacuum lines it definitely sounds like a vacuum leak.
Stupidity has an incredible ability to overcome almost any obstacle.
http://www.fquick.com/Caboose73
http://www.aleromod.com/forums/showthread.php?t=27805
Caboose73 is offline   Reply With Quote
Old 09-02-2011, 09:30 PM   #3
boost leak test it
Old 09-03-2011, 09:51 PM   #4
widbyj
widbyj's Avatar
Clean the IAC assembly.
Old 09-05-2011, 10:41 AM   #5
knowledge8069
knowledge8069 is an unknown quantity at this point
I know this is probably something you checked, but is the cable on the throttle body too tight? It's the little screw-in plastic piece that tightens up the cable to the pedal, right next to the cruise control cable.
knowledge8069 is offline   Reply With Quote
