Old 01-30-2005, 12:45 AM   #1
slikrb
ok i am having some big problems. my car was fine last night then today when i went to start it i runs like poop. it doesnt shift even at 5000rpms but if i let off the gas it shifts. i have a 2002 3.4L V6. i just hit 50000 miles. Someone please help me. i think it is a tranny problem issed:
Old 01-30-2005, 01:57 AM   #2
Voodosoup
Any other symptoms?
Like electrical problems, i.e. guages acting goofy, intrument cluster lights and needles going wacky. Or is it just the shifting problem?
When I got water in my motor and my throttle position sensor went bad the car wouldn't shift/shifted very erraticly. Also I had the alternator go bad and this also caused shifting problems as the tranny is electronically controlled.
Are you throwing any warning lights? If so fin an autozone or advance auto and go get a free code scan.
that's about all I can think of......
Old 01-30-2005, 02:29 AM   #3
AftermathAlero
it sounds like a sensor problem.. more than likely the MAF sensor. When my MAF wire harness broke off the main 12 volt wire to it.. the car misfired, hard shifted.. etc.
Old 01-30-2005, 03:06 AM   #4
slikrb
service engine soon light is on
Old 01-30-2005, 07:01 AM   #5
Naich
The Founder
Naich's Avatar
can you be a little more exact as to what the problems are specifically? It could be a million things from the original description.
Old 01-30-2005, 08:54 AM   #6
germ
drive over to autozone and have the code read fo free lol
then buy the sensor thats sending the error
then install it
i bet its not your tranny
im leaning towards a TPS sensor
Old 01-31-2005, 08:46 PM   #7
AGT
AGT's Avatar
^^ I agree...or MAF...once I took the clip of the MAF and trusted a friend to replace the clip while I put the front wheel on and he bent a prong and the thing ran like 1000 RPMs over its normal. No biggie I just rebent the prong back when i fianlly found it to be that.
Have a good day
Old 02-01-2005, 01:04 AM   #8
Could be bad plugs and causing a misfire
