12-08-2005, 12:58 PM
So I was calling around for some new tires and after giving the tire size to the two places I called they told me I had the performance Alero? being a semi newbie I've never heard of this. What does this mean? just that the tire size and wheels are bigger (16" instead of 15"'s)? anyone?
12-08-2005, 01:04 PM
H&B Shipping Agent
well the GX or base Model came with 15 inch steel wheels and all the other models come with 16 inch alloy wheels. I wouldn't call them performance, but if you have the 16 inch wheels I guess you could consider your car the sportier model since it probably has the V6.
12-08-2005, 01:13 PM
mine is a gl with 15s, but they're not steelies.
12-08-2005, 01:19 PM
Defeat < Giving Up
i have the 3400 v6, and i have 15's.
WhiteLiquid
12-08-2005, 01:48 PM
I got the GLS with 16s
It is a "Performance" package with the bigger wheels and the suspension, however the springs and sturts are the same on all Aleros. The OEM 16" tires are performance tires of some sort, but they suck anyway
12-08-2005, 02:12 PM
Thanks guys I kinda figured if was just a tire and wheel combination.
Redog you said suspension.. what's different?
Again thanks
12-08-2005, 02:17 PM
Designated Drunk
nope...the gx had the option of 15" rims too, not the steelies..
I'm baaaackk
12-08-2005, 02:46 PM
Nothing, but it says on the window sticker "Perfomance suspension package" but only on the GLS's :rolleyes: It's just a gimmick
12-08-2005, 02:52 PM
The only thing you they really need to know thought is the rim size if its a 15 or a 16 inch
Their is a different few strut and spring package for our cars. I just found this out well looking up OEM parts for a project in my estimating class. The only thing you they really need to know thought is the rim size.
Sorry to jake this thread for a post or two. But all aftermarket Struts are the same but GM has three different set ups that came on the cars 99 (GM# 22064731)came all the cars except for the sport package (GM# 22064770)
00-04 all cars with the 2.4/2.2 came with sport package (GM# 22064770) and the 3.4 aleros came with (GM# 22064788) Just thought you all might like to know. Same thing with the control arms two different ones.
DONT BUY A JEEP.
It will take over your Life.
12-08-2005, 03:52 PM
Junior Member
So is there any ride height difference between the regular and the "sport" suspensions? My wife's 02 GLS has the sport package and I'm thinking of putting Eibach's on it, but would it still be lowered 1" up front and 1.5" in the back, or would the difference be less?
12-08-2005, 04:07 PM
if there is any difference (which i doubt) it is minimal.
the spring makes the car lower, not the strut. since you are changing the spring then yes you will get that result, if not a little more after they settle.
12-08-2005, 06:36 PM
So wait, the "sport supsention" shows up only on the GLS, but it really isnt anything? because ive seen that on a few in the lot when i was looking for mine (GLS V6 16" polished)
12-08-2005, 07:52 PM
Wrong.
15 Inch rims are also on GL and an option on the GL2. However the GL2's (and GL3's) probably got the 16 inche ones. GLS had polsihed rims 16 inch standard. I think the GX even has rims if it had the "Sports" package
12-08-2005, 08:09 PM
my GL2 had sport suspension on it
12-08-2005, 09:44 PM
GL1,2,3,4 GX GLS sport suspention this is way confusing.... haha
12-08-2005, 10:02 PM
Originally posted by Redog+Dec 8 2005, 12:46 PM--><div class='quotetop'>QUOTE(Redog @ Dec 8 2005, 12:46 PM)</div><div class='quotemain'><!--QuoteBegin-teebo7@Dec 8 2005, 01:12 PM
Heh, Redog....I think on the sport suspension, they tighten the strut tower mounts about 3 lbs tighter
12-08-2005, 10:10 PM
i'm still under the belief that i have the "franken-alero"
its a GX with a V6. no special features of any kind, except the bigger engine.
i've never really compared my suspension to others (besides lowered ones) so i have no clue if i'm "sport" or not.
but i do have the "performance" tires. and redog was right... they blow... ...big nasty chunks.
12-08-2005, 10:11 PM
i have the gl2, and it has sport suspension and 16 inch painted alloy rims. im curious of the actual differences between the ride height, if any.
12-09-2005, 12:23 AM
MINIac
Sport package got you slightly stiffer springs and a little thicker swaybar, plus the bigger wheels, different tires and all that jazz. Ride height was 5.0" on all Aleros.
12-11-2005, 06:58 PM
Originally posted by shockz+Dec 8 2005, 06:52 PM--><div class='quotetop'>QUOTE(shockz @ Dec 8 2005, 06:52 PM)</div><div class='quotemain'><!--QuoteBegin-Vtolds@Dec 8 2005, 01:04 PM
Wrong.
[/b][/quote]
That is correct. The GX sports package came with a spoiler and 15 inch alloy wheels.
2005 Honda CR-V AWD
