09-05-2013, 04:12 PM
Need a part for the car
Well my svs anti-lock an trac- off are on and it ended up being the connector on the passenger side does anyone have one they can part with
09-05-2013, 06:20 PM
You go to auto store, ask for wheel bearing or "hub assembly" Replace it and its fixed.
Originally Posted by Oldsnut
Originally Posted by tipnitty
09-05-2013, 06:29 PM
Nope it's the connector for the car harness not the hub itself
09-05-2013, 06:51 PM
Its built into the hub i believe i dont think you can buy just the connector. Or anyone will have one lying around.
09-05-2013, 06:58 PM
No it's the connector from already on the car that connects the cars harness to the hub the one that's clipped to the bottom of the control arm that's the connector I need
09-05-2013, 07:11 PM
It could just have corroded... you might have to splice it open and clean the wirea to make proper connection again... i think there's a how to on here somewhere...
09-05-2013, 07:20 PM
The wire is broken at the base of the connector
09-05-2013, 07:57 PM
Cut, strip sheet, solder together.
Or if you still want the weather pack connector, which I would too, see what kind of condition it is in the local junkyard. Pin removal is pretty easy
09-05-2013, 07:59 PM
I was trying to avoid driving it as its developed a cooling issue and the parts tard is 45 min away
09-05-2013, 08:20 PM
I'd fix the coolant issue first...
09-05-2013, 08:33 PM
Yeah I haven't had time to troubleshoot it just yet but from what it's doing I'm thinking tstat or Cooling fan issue and before anyone asks the temp gauge climbs slowly above half and keeps climbing whil sitting at idle but while driving its normal
09-06-2013, 01:39 AM
So don't stop *grins*
Could also be the water pump - if the impellers are failing, you'd see the same reaction. Notice "failing", not "failed" ... my stepson's Taurus, when we swapped the WP, had about 1/2 vane left of the 7 ...
RwP
09-06-2013, 10:54 AM
Yeah not stoping would be great but people here don't know how to drive and thanks ill have to check into that
09-06-2013, 01:01 PM
09-06-2013, 03:47 PM
The part I need is in picture 7 the connector itself
09-06-2013, 04:21 PM
did you see how i "rebuilt" mine?
09-06-2013, 05:04 PM
Ye I was hoping to just get a connector and splice it in
09-06-2013, 09:04 PM
thats still a very easy option. im sure yoru local dealer will have "terminals" not "connectors" in stock readily available. otherwise take a trip to wrecker.
09-06-2013, 10:34 PM
Ok thanks for the help i think tomorrow ill be at the yard finding some stuff
